Old 10-12-2012, 01:29 AM   #1
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
DIY ECU removal
Tools:
10mm crescent wrench (ratcheting preferred)
Needle nose pliers
Time:
About 15m
Difficulty:
Beginner
The hardest part about this job is knowing where the ECU is, as well as working in an inverted position. The first few steps can be bypassed, but they allow a little more access to the ECU and bolts.
The ECU is located on the passenger side of the vehicle, right above the kick panel, behind the dash.
First, to get more light in remove the end piece from the dash. You can take it off by pulling up and away from the bottom. It's held in by a few clips and comes off fairly easily
Once that is off, you can pull this piece off it's pegs. They will slip right out. If you can't get them off easily, you will have another shot at it after the next step.
If getting to the lower peg was hard for you, here's your shot to get it.
To remove the glove box, Open it all the way, and then push the sides in towards the center just enough to get the tongue past the notch it rests in. There is one on either side. Once you get both of them out, the glovebox will pull straight out, off it's hinge.
At this point you will get your first glimpse of the ECU. From here you can use your needle nose pliers to unplug the ECU. Be careful here, I broke a piece of the plug release in the process.
From this point we will move to our back. The ecu is mounted to the firewall at 2 points. Both bolts are 10mm, with a short clearance on the lower screw (circled in the top right of the picture below). If you have a 10mm ratcheting crescent this job is a breeze.
The other screw is mounted higher up, You have a little more room to work here.
Once the bolts are off you can just work the ecu out from around the harness, and Viola!
Reverse the steps to put it back in.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 10-12-2012, 01:59 AM   #2
cuddefred
Drives: Black 86 GT
Thanks for this. Noob question - how and where do we plug into the ECU to flash it in the 1st place? I'm sure I am supposed to know this but I don't
cuddefred is offline   Reply With Quote
Old 10-12-2012, 02:04 AM   #3
Hawaiian
That guy
Hawaiian's Avatar
You flash a vehicle by plugging the cable into the ODB2 port (located right above your knee when you're pressing the gas pedal), not the ECU. Replacing the ECU should only be necessary during a catastrophic failure.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 10-12-2012, 02:18 AM   #4
Yruyur
Yruyur's Avatar
Great writeup.
Old 10-12-2012, 07:50 AM   #5
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Or if you're going to a complete stand alone aftermarket ECU.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 10-18-2012, 11:44 PM   #6
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
This DIY just saved me.
Finished taking out my ECU about 5 mins in the rain outside. No open doors laying inside upside down in the car haha tight squeeze
Great DIY
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 10-19-2012, 04:03 AM   #7
Hawaiian
That guy
Hawaiian's Avatar
Great DIY
I'd give you a thanks, but... Yeah. Having to do this sucks for you.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 10-21-2012, 02:56 PM   #8
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
NOOB QUESTION:
whats the point of doing this mate?
Obja is offline   Reply With Quote
Old 10-21-2012, 03:16 PM   #9
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Originally Posted by Obja View Post
NOOB QUESTION:
ECUtek was having some issues with tunes and required owners to ship their ECU in to fix.
cobrabyte is offline   Reply With Quote
Old 10-21-2012, 11:28 PM   #10
JDMenrique
DEEEERP
JDMenrique's Avatar
is it me, or the more and more i tear into my car(FR-S) the more i think it was solely made by subaru...?
JDMenrique is offline   Reply With Quote
Old 10-23-2012, 12:08 PM   #11
Hawaiian
That guy
Hawaiian's Avatar
NOOB QUESTION:
Some of us were having a few issues....
Also, as lord takuban said, some people might do a standalone ecu.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 10-23-2012, 09:23 PM   #12
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
As far as I know, toyota made the fuel injection system. I think thats about all they made..
RedRocket is offline   Reply With Quote
Old 05-23-2013, 02:14 PM   #13
Jason@Nameless
Jason@Nameless's Avatar
Drives: '88 BMW 535is Turbo
Tools:
One note, there is a bracket in the foreground of this photo above that you can see two weld nuts attached to - there is a secondary bracket on BRZ's that holds another control unit in the way of the ECU. You'll have to remove the bolts attaching through to those weld nuts and also disconnect the three plugs off the bottom of that control unit (which are accessible at the far rear underneath the glove box mounting points to the right) and remove it in order to get to the ECU.
Jason
Jason@Nameless is offline   Reply With Quote
Old 01-14-2016, 12:10 PM   #14
Astroboy
Astroboy's Avatar
Drives: None
I'm planning on swapping mine out because of the p0018 issue I am having. Also, if I had a custom tune using the ecutek, will I need to recalibrate the tune, or can I just program the tune righ back in?
Astroboy is offline   Reply With Quote
Badge Removal DetroitJake Cosmetic Modification (Interior/Exterior/Lighting) 5 10-01-2013 02:35 PM
Dent Removal 7thgear Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-23-2012 06:38 PM
snorkel removal Bu-Tang Engine, Exhaust, Transmission 4 09-01-2012 11:40 PM
headlining removal encity5 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-21-2012 07:06 PM
Clear bra removal. Any one try it? digital_assassin Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 07-13-2012 02:30 PM
