Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
10-12-2012, 12:48 AM | #1 |
Drives: '23 CWP BRZ
TPMS?
Well, it starting to get into the 60's in Florida. Today after a car meet, hopped in the FRS, turned it on, and I had that little glowing exclamation point. Stayed on the whole drive home (40 minutes.) And as of last checking, it's still on.
So I searched, apparently my tire pressure is just low? Is there a way to disable this TPMS? I don't want to be alerted when my wheels drop like 1PSI under what they have it set at...seems like a hassle to me. I'd rather just check on my own normally. |
10-12-2012, 12:50 AM | #2 |
Registered you sir
Drives: 99 impreza coupe
No. Just fill them properly
The Following User Says Thank You to chulooz For This Useful Post: | Subie (10-12-2012) |
10-12-2012, 07:40 AM | #3 |
Drives: BRZ and NA
Correct. I hate TPMS because of hassles it can cause. Especially because our cars can't store more than one set of TPMS codes. But, if your TPMS light stayed on after 40 minutes of driving, at least one of your tires is more than one or two psi low. Driving heats up tires, and if the light stayed on even after the tires were heated up, then your pressure is lower than you thought. Did you actually check your pressures when you got home? I can't tell by your post. |
10-12-2012, 08:14 AM | #4 |
Boostin'
Drives: FRS-T
they usually only come on at about 25psi, so when they light up, it really is time to check your pressures... there has to be a way do get rid of the system, i just got a BRZ in the shop and it doesnt have TPMS
10-12-2012, 08:52 AM | #5 |
You can probably take out the bulb in the dash light. I'd just deal with it, though - I doubt highly that it's sensitive to +/- 1psi....engineers are generally smart enough to know that tire pressures will fluctuate within a certain range during normal heat cycles, and I'm sure they did extensive testing during the development on all the various components that went into each system. It wouldn't make sense that they would keep in a system that was throwing codes during normal driving conditions. If the light goes off, just fill up your tires!
Ultramarine 2013 Scion FR-S 6MT
10-12-2012, 10:23 AM | #6 |
EightSixClub Co-Founder
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Not for me, mine came on about a week or two after owning it on a colder day. When I took it into the dealership to take a look at the CEL, I asked them to also check the tires. They said they were at 32 psi, so I asked them to bump it up to 35 psi as the door frame suggests.
10-12-2012, 01:59 PM | #7 |
Drives: '23 CWP BRZ
Just turned off today after driving on the interstate for around 30 minutes. Seems like TPMS is too sensitive.
10-22-2012, 08:59 AM | #8 |
Meh!
Drives: Satin White, 86, Manual
Nitrogen?
10-22-2012, 10:08 AM | #9 |
Drives: BRZ(sold), STI
Mine came on at around 30psi.
10-22-2012, 10:40 AM | #10 |
The Answer
Drives: Mazda 2
Did you actually checked the pressure? It will come on when it's "significantly" lower than what it should be.
10-22-2012, 10:57 AM | #11 |
^Me? I checked as soon as the light came on.
Similar Threads | ||||
TPMS light | michael317 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 50 | 08-05-2014 04:12 PM |
TPMS Sensors.. | Dave-ROR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 04-08-2014 01:22 PM |
TPMS | smbrm | CANADA | 2 | 09-21-2012 11:17 AM |
Multi TPMS? | Justin.b | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 08-11-2012 06:25 AM |
so what is everyone doing about their tpms? | Hachi6 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 07-22-2012 05:04 AM |
