Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-17-2012, 06:42 PM | #1 |
Shift Knob
Has anyone else have the top cap of the shift knob coming off?
The Following User Says Thank You to Zoomryder For This Useful Post: | winsometang (04-10-2013) |
09-17-2012, 07:03 PM | #2 |
Drives: Toyota 86 GT
Noticed it just last night to be honest!
09-17-2012, 07:14 PM | #3 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
There is no real stop built into the OEM shift knob so it makes it possible to tighten the knob down too far and then it will push the top cap off. People have been complaining about the knob turning on them so they tighten it more and this happens. Some have used lock tite or other types of adhesive to keep it tight without turning it too far.
I got an BRZ OEM knob that I am using in my 6 speed Spyder. I had the same problem with the knob not tightening enough. I ended up fabbing a stop for it by cutting the end off of a 12M x 1.25 bolt, cutting a screwdriver slot in it and screwing it into the knob. Then I put the knob on and tightened it until it hit the new stop. It will not screw in far enough to lift off the top anymore and it stays tight.
So many modders have more cents than sense!
09-17-2012, 07:23 PM | #4 | |
Drives: CBS BRZ Limited 6MT
The knob doesn't have a top portion. The shifters is supposed to bottom out at the cap. Overtighten it and the cap will start to come off. It may also happen during a hot day if you have the knob tightened down fairly well.
Back in (Crystal) Black.
09-17-2012, 07:27 PM | #5 |
Sports Car = Anti-Drug
Drives: 2014 Honda CBR600RR
Thankfully, mine's in fair shape... 4k miles on the car, thus far.
"Did you know that this car comes with 300 horsepower in its stock form? 200 from the engine, 50 in its chassis, and the final 50 within the driver who can make the most of it."
Texas BRZ |
04-09-2013, 08:39 PM | #6 |
Hot Lava 6MT
Drives: Hot Lava FR-S
This just started happening to mine. Took it in for my 7K service and they will be replacing my knob.
Similar Threads | ||||
Shift Knob | Jwong | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 29 | 12-12-2014 01:33 AM |
Kartboy Shift knob | Spartan65 | Interior Parts (Incl. Lighting) | 8 | 10-03-2012 06:18 PM |
any other shift knob? | oso_25 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-31-2012 01:38 AM |
TRd Shift Knob | GaN-MaN | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-24-2012 01:57 PM |
