Old 09-11-2012, 05:58 AM   #1
bloomy116
Drives: 2010 Honda Civic Si
5k oil change, worried about changes....
So a couple days ago I took the BRZ in for its first oil and filter change at 5,000 miles. Before the oil change I was used to shifts being a little notchy as described by others, but not to the point where I found it bothersome. Well afterwards I've noticed the shifts are quite smoother, similar as described by prest1ge here: http://www.ft86club.com/forums/showthread.php?p=394308. For example, I used to almost always have issues with shifts into second, but now there is hardly any resistance, with smooth shifts into second almost every time.
I've read posts about others changing oil at 1k miles, but I kinda shrugged it off as being a little overly paranoid since the manual states 7.5k for the first oil change....but now I'm freaking out a little. Was this really due to significant amounts of metal shavings in the oil? And if so, did this cause significant wear to the engine, or was it probably minimal? I was assuming before that if there were any shavings that the filter would have caught most of them, but now I'm not so sure.....
bloomy116 is offline   Reply With Quote
Old 09-11-2012, 06:29 AM   #2
ozone42
Drives: SSM BRZ Limited
No, your engine oil will have 0 effect on your transmission feel.
Did the ambient temps in your area change over the last few days? That can have an effect, albeit a small one and only when you first tart driving.
ozone42 is offline   Reply With Quote
Old 09-11-2012, 07:08 AM   #3
gmookher
they changed you motor oil right?
or are dealerships swapping out tranny fluid too?
gmookher is offline   Reply With Quote
Old 09-11-2012, 01:39 PM   #4
bloomy116
Nope. Just oil and filter.
Old 09-11-2012, 02:15 PM   #5
gmookher
so any perceived change in how it shifts is 100% perception sorry
The Following User Says Thank You to gmookher For This Useful Post:
ft86Fan (09-11-2012)
Old 09-11-2012, 08:23 PM   #6
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Yeah, not sure why you would think an engine oil change would affect your transmission in any way.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Anyone worried about not fitting in the car? budakajana AUSTRALIA 35 06-27-2012 07:55 AM
Worried about Buying a Manual cmspooner BRZ First-Gen (2012+) -- General Topics 100 06-06-2012 09:22 AM
Worried about the demographic that will buy the frs? RearDrive Scion FR-S / Toyota 86 GT86 General Forum 108 05-10-2012 06:18 PM
Should I be worried about bad dealer reputation? Deepmist Scion FR-S / Toyota 86 GT86 General Forum 5 05-06-2012 12:01 AM
Things that I'm worried about... CSOCSO Scion FR-S / Toyota 86 GT86 General Forum 35 11-23-2011 12:37 AM
