Old 09-05-2012, 03:24 PM   #1
CBR600RR
Drives: Raven Black
15 inch rims for winter?
Tried a quick search, but couldnt find out if a 15 inch winter tim will fit on this car.
Anyone fit a 15 inch rim yet?
Old 09-05-2012, 03:40 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Not all 15" wheels will fit. Most that will might be more than what you may want to spend on winter wheels. Best bet would be to stick to 16" wheels if you really want to go smaller.
Old 09-05-2012, 03:51 PM   #3
FRiSson
Drives: FR-S MT
Tire Rack is recommending 16" for downsized wheel/tire packages. The ideal is to get a narrower patch while maintaining necessary underbody clearance for snowy roads.
FRiSson is offline   Reply With Quote
Old 09-05-2012, 04:33 PM   #4
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
That's exactly what I was thinking. I suggest combing through craigslist and look for some 16 steelies from a vw golf or beetle or something. Both of those are the correct lug pattern, cheap, and you should be able to run a 195 or 205 with a 55ish section.
SkitterSkotter is offline   Reply With Quote
The Following User Says Thank You to SkitterSkotter For This Useful Post:
CrowsFeast (06-17-2022)
Old 09-05-2012, 04:57 PM   #5
FRiSson
Drives: FR-S MT
I wouldn't get used wheels unless they are in really good condition. Failures due to rust, damaged and improperly cleaned wheels are more common than people think - and quite dangerous.
Old 09-05-2012, 05:12 PM   #6
wheelhaus
wheelhaus's Avatar
the whole narrow patch concept is debated. With normal packed snow and snow tires, extra sufrace are (read normal/wide) helps to get more surface grip from the additional sipes and edges. With deep fluff or slush, narrow helps to cut through and get to the harder surface/pack.
I also haven't seen any 15" wheels, someone could measure the brake caliper clearance to see if they'd even clear the ID of a 15" rim... I also think 16" steelies would be the best route.
wheelhaus is offline   Reply With Quote
Old 09-05-2012, 06:31 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
What does the diameter of the wheel have to do with the tread width?
Here's a 205/50-17 that will fit on the stock wheels, narrow the tread pattern, and provide 1/4" more clearance.
http://www.tirerack.com/tires/tires....WCXL&tab=Sizes
Old 09-05-2012, 06:41 PM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
The front brakes are WRX brakes. So 15" wheels will fit if the barrel is shaped properly. Team Dynamics Pro Rally1 and BRAID WinRace T will most certainly fit. Some other miscellaneous OEM wheels will work too, but that would take some digging to find out. Best thing is just stick with 16" or larger.
For those wanting narrow tires, check out the BRAID Winrace N in 16x5 or 16x5.5 and wrap them in Dunlop Graspic DS-3 in 175/60-16. It's only 5mm less diameter but should cut though anything. Or go to 195/60-16 Pirelli Winter Sottozeros and get 7mm of lift.
Old 09-05-2012, 06:50 PM   #9
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
quik1987 is offline   Reply With Quote
The Following 5 Users Say Thank You to quik1987 For This Useful Post:
cobrabyte (09-18-2012), hmong337 (06-29-2013), RazBRZ (01-16-2013), wheelhaus (09-05-2012), WRB-DZA-BRZ (09-05-2012)
Old 09-05-2012, 06:55 PM   #10
Draco-REX
Corner Junkie
Draco-REX's Avatar
Originally Posted by quik1987 View Post
The bottom ones are Volk TE37s, not sure about the top, OZ Alleggeritas?
Old 09-05-2012, 07:08 PM   #11
xcelir8brz
Drives: 2013 BRZ Limited
I have sixteens 205 with graspics.
xcelir8brz is offline   Reply With Quote
Old 09-05-2012, 07:49 PM   #12
WRB-DZA-BRZ
Cookie Monster
WRB-DZA-BRZ's Avatar
Drives: 2013 Subaru BRZ Premium 6-MT WRB
I have a set of 15x6.5 Konig Subzero wheels currently on my Neon that I'll try fitting to the BRZ when I get it. It's got 205/50-15 rubber in right now. If the wheels fit, I'll put some 195/65-15 Michelin X-Ice tires on them, and use them for winter.
WRB-DZA-BRZ is offline   Reply With Quote
Old 09-05-2012, 08:40 PM   #13
roddy
roddy's Avatar
Drives: '13 Ultramarine
I'm undecided if I'll go with a 16" steelie with 205/55s or 195/60s, or If I will try 15" steelies. One thing is for sure though... I'll be running WS70 Bridgestone Blizzaks. A friend owns a tire shop, and I'll be paying him a visit in a couple of weeks while I'm on holidays. I'll try both sizes of wheel before I order tires, and post up what I find out about the fitment of 15s.
Old 09-06-2012, 11:23 PM   #14
FRiSson
Drives: FR-S MT
I've been checking out 16" tires. The X-Ice3's seem to be at the top of the heap for non-performance winter tires. The Blizzaks are close, but don't have the commanding lead that they had when the were the first really effective ice tires. On the other hand, General Altimax Arctic are about 40% cheaper and get ratings nearly as high as the others. The only problem is that they are noisy and there are reports of vibration at speed. So I am not sure which ones I will get. As far as the size to use, I am not convinced that smaller diameter wheels are absolutely better - I am a little skeptical. But their lower cost is pretty enticing.
Winter Rims RandomHero Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-05-2012 08:06 PM
19 inch rims too big? Liquidcell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 09-03-2012 01:07 PM
Winter Tires and 17" Rims?? stalon320 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-03-2012 08:33 AM
Cheap winter alloy rims Sport-Tech CANADA 52 04-18-2012 10:30 PM
Photoshop Request: FT86 with 16 inch rims? EJ20 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 02-25-2011 04:01 AM
