Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-06-2024, 01:50 PM | #1 |
Rear End Shifts on Accel/Decel
Been a long time since I posted here.......have a 2013 BRZ and recently I have noticed when driving the car and accelerating up through the gears that when I shift and let off the gas and then get back on the gas, the rear end is changing directions. Can also make it do the same thing by hitting and letting off the gas. Have visually looked at the rear bushings and don't see anything wrong by the eye. Wondering if anyone else has had this problem and what it was?
Thanks. |
05-06-2024, 02:28 PM | #2 |
Drives: 2018 BRZ
I'd check all drivetrain bushings - rear subframe, diff mounts, transmission and shifter mounts and engine mounts. All of these contribute to the rear being squarely.
In addition, check your suspension links, especially toe arms. Make sure everything is tight, bushings are in good shape and toe isn't out of whack (slipping or loose toe adjuster, for example). |
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post: | RedReplicant (05-06-2024), strat61caster (05-07-2024) |
05-06-2024, 06:22 PM | #3 |
Drives: '23 BRZ
What are your tire pressures? What you describe is how a Torsen diff behaves when you have rear tires of different diameter, or one is at lower pressure.
The Following User Says Thank You to ZDan For This Useful Post: | RToyo86 (05-07-2024) |
05-07-2024, 07:38 PM | #4 |
I’ve also seen this when cross weight is jacked, ignore if on non adjustable spring perches.
Yesterday, 05:21 PM | #5 |
Drives: 2023 BRZ, 2018 Golf R 6MT
I'd check wheel bearings and axle nuts, too.
Today, 09:42 AM | #6 |
Drives: 2016 Scion FRS Release Series 2#439
I experienced this. My right rear tire was worn significantly more than the left. The rear of the car stepped right during hard accelleration. No effect noticed during braking however.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) |
Today, 09:52 AM | #7 |
Tire pressures were the first thing I checked and all were good. Wear is even on all tires as well. Car is also puling to the right as well and it has driven straight as an arrow since I've had it. As far as I know there has been no curb contact to knock alignment out of whack. Going to take it to the dealer next week probably as driving it out on the interstate it has a constant tug to the right which is annoying as hell.
Similar Threads | ||||
Slight pull to the left on accel, pull to the right on decel | mightaswell | Issues | Warranty | Recalls / TSB | 18 | 01-12-2021 07:50 PM |
Whiteline Rear Transmission Insert Noise in Decel Only | M0nk3y | Engine, Exhaust, Transmission | 9 | 03-10-2020 07:51 PM |
Perrin rear shifter bushing = sloppier shifts? | abutterman | Engine, Exhaust, Transmission | 9 | 02-26-2016 12:41 AM |
Transmission kick under accel | SCharged | Issues | Warranty | Recalls / TSB | 11 | 03-18-2014 11:24 AM |
Apexi SMART Accel Controller | 808Raven | Engine, Exhaust, Transmission | 2 | 10-11-2012 07:54 PM |
