Old 03-04-2024, 01:51 PM   #1
abyssFT86
Drives: 2020 BRZ Limited
Sway bar bushing heat protection
My passenger side sway bar bushing is getting hit with a lot of heat from the overpipe at the track. The bushing is now seeping fluid out and visibly cooked. I think this is why my car has had so many issues with creaking noises after heating up. See pictures of driver side (left - pristine) and passenger side (right - extra crispy) in the image below.
I am going to replace the bushing to stop the racket coming from the sway bar but want to see if I can get a more permanent fix while I'm in there.
Has anyone tried this Verus heat shield?
https://www.verus-engineering.com/sh...t86-4358#attr=
People also mentioned venting to help cool the overpipe but I can't imagine this will drastically change the situation given the location of the vents.
https://www.ft86club.com/forums/showthread.php?t=152472
Let me know if there are better options out there.
Options aside, I'm curious how some members hit this issue and not others. I saw posts from others who track but still have pristine bushings. I have a stock exhaust and bushings so I'm surprised I ran into this. Wondering if there are other factors that matter here.
abyssFT86 is offline   Reply With Quote
Old 03-04-2024, 05:55 PM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I haven’t experienced a failure of that bushing, possibly because my Overpipe and Frontpipe are ceramic coated. You might try some header wrap on your overpipe to protect the bushing.
I use header wrap on my mid-pipe where it passes below the CV joint which has been known to suffer heat damage in track cars. Mine remains unscathed thanks to the wrap.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. A052 on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 03-04-2024, 08:21 PM   #3
Code Monkey
Drives: Subaru BRZ
I had this happen when my ACE header decided to separate from the overpipe, pics here. Some sort of heat shield should definitely help.
Code Monkey is online now   Reply With Quote
Old 03-06-2024, 09:39 AM   #4
abyssFT86
Thanks, I think you're right that exhaust wrap or coating is a big factor here. The folks I saw who didn't melt also mentioned ceramic coating. I like the header wrap idea as a cheaper quick fix too. thanks!
Old 03-06-2024, 11:57 AM   #5
Muskoka800
Yes, a ~$20 roll of wrap, a few gear large clamps and you’re set.
Good luck!
Old 03-06-2024, 04:52 PM   #6
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I had this happen with my OEM bushings in the front during expensive autox usage. The OEM bushings are fluid filled. So it might be heat, might be overuse, or both. I'd reckon it's overuse and track driving.
I'd skip the whole heat shielding idea and just get new polyurethane bushings without fluid inside. They'll hold up better and not leak (obviously). Just get ones to fit the OEM bar diameter - I'm sure they make them.
cmiovino is offline   Reply With Quote
Old 03-07-2024, 06:38 AM   #7
abyssFT86
I like the poly idea but I was under the impression that poly still melt easily from this thread: https://www.ft86club.com/forums/showthread.php?t=121185
Another poster mentioned trying them here and still having meltage until they heat wrapped the pipe: https://www.ft86club.com/forums/show...0&postcount=23
Old 03-07-2024, 02:28 PM   #8
norcalpb
norcalpb's Avatar
I think that vented oem sway bar mounting bracket trim piece is to provide cooling for the secondary cat. The gr86 also has a new NACA duct on the skid plate that I believe is for cooling the primary cat. I’m thinking it’s all emission related but could be wrong.
Old 03-07-2024, 06:30 PM   #9
abyssFT86
That makes sense, now that I read the OP's post more clearly it seems like they thought it was for the bushing but later realized it's for the cat. Will cross that one off the list :-)
Sway bar bushing issue Spuds Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-29-2023 10:44 PM
Failing Sway Bar Bushing? jkost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-20-2021 04:14 PM
Rear sway bar bushing T0rt0r0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 11-10-2018 02:41 AM
Mounting aftermarket header. Do i have to wrap/ ceramic coat for heat protection? giorgi0424 Engine, Exhaust, Transmission 9 03-03-2017 08:58 PM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
