Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 02-16-2024, 10:25 PM   #1
ChesterV
New BRZ Guy
Drives: 2022 Subaru BRZ
Question How accurate is 6MT Fluid Capacity?
I changed my transmission and differential fluid today.
Going by the owner's manual, the car needs 2.3qts of Transmission Fluid and 1.22 Differential Fluid.
I used Motul Gear 300 on both. However, when I was filling up my transmission, on my 3rd quart. I have reached almost half of the bottle and it didn't spill out of the fill plug. Now I'm worried that I underfill my transmission.
Should I be worried even I did not fill the transmission until fluid spills out considering I have put the right volume of fluid from the owner's manual?
ChesterV is offline   Reply With Quote
Old 02-16-2024, 11:59 PM   #2
Ultramaroon
chicken tonight
Ultramaroon's Avatar
It's fine. Doesn't need to be perfect. Is the rear sitting lower than the front?
ChesterV (02-17-2024)
Old 02-17-2024, 01:11 AM   #3
ChesterV
New BRZ Guy
They were pretty even. It was on 4 jack stands on a evenly drive way. Drained 30-45 minutes after running 15 miles.
Just worried because everywhere I look, everyone says the same to fill up until it overflows. Now I'm thinking since mine don't overflow, my transmission is underfilled even though I put approximate 2.36quarts(if calculation was perfect)
Old 02-17-2024, 01:42 AM   #4
Ultramaroon
chicken tonight
It's probably going to annoy you until you verify for yourself. I bet after all the work of lifting and removing the fill plug, you won't get more than a couple ounces in.
But the peace of mind will be worth it.
AK2112 (04-25-2024)
Old 02-17-2024, 10:24 AM   #5
ChesterV
New BRZ Guy
Lol I lost sleep thinking about it. I don't have time until next week to top it off. I think I should be fine since I followed the owner's manual
Old 03-23-2024, 09:16 AM   #6
Mcgiiver
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
If you have 2 1/2 qts in there, and it still did not overflow, don't worry about it, you are close enough. There is a good possibility that if you added just 1/8 ounce more, you would get the overflow. At 2 1/2 qts you have plenty of oil for proper lubrication. These transmissions are not Swiss watches.
Mcgiiver is offline   Reply With Quote
Old 04-25-2024, 02:43 PM   #7
gnarjunkie
Drives: '23 GR86, '17 BRZ
I found that since there's always a bit of spillage plus you won't get 100% of the fluid out of each bottle that it takes a bit more than you'd think. I always just go til it spills out.
I highly doubt you'd hurt anything driving it for a few days. But I'd personally top it off as soon as I had a bit of free time. Only would take 10 min or so to do.
gnarjunkie is offline   Reply With Quote
fluid, manual, manual transmission, transmission
AFR accurate on Torque App? stevo585 Software Tuning 14 07-16-2016 10:48 PM
How accurate is FRSProject? lupindub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-19-2016 09:19 AM
Clutch system/MC fluid capacity? ZionsWrath Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-08-2014 08:40 PM
Disp Temperature not accurate marinjim Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-22-2012 08:16 AM
How accurate? Maps316 BRZ First-Gen (2012+) -- General Topics 18 08-02-2012 08:28 AM
