BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
10-26-2023, 12:58 AM | #1 |
Drives: slow
Acceleration problems.
Hello!
I have a 2016 brz modded with tomei uel header, perrin 2.5 catback, and is tuned on delicious tune stage 2. Car has been driving great specially as a daily driver but recently (past 3 months) I got my clutch done, a month after clutch was done, i've had acceleration issues.. local shops couldn't figure out what was wrong with car.. no CEL or anything but the car is not 100% .... last week I found out I had a broken v-band on my exhaust, replaced it, drove around it seemed better but still seems having acceleration issues. I'm hoping it would be just a minor exhaust leak this time. or maybe spark plugs? any help would be appreciated! |
10-26-2023, 02:06 PM | #2 | |
Drives: 2018 Subaru BRZ Limited with PP
10-26-2023, 04:15 PM | #3 | |
Drives: slow
*drove car around today, accelerator seems to respond better but there's still a delay with rpm needle going up from time to time. RPM drop during idle isn't as terrible I thought it'd be spark plugs since I haven't changed them and I'm almost at 90,000 km and I'm trying to get in contact with my local tuner about the logs. |
11-07-2023, 02:02 PM | #4 | |
11-07-2023, 02:22 PM | #5 |
friendly
Drives: 17' 86
Post logs
Seek comfort in discomfort.
The Following User Says Thank You to alphasaur For This Useful Post: | Ultramaroon (11-07-2023) |
11-10-2023, 09:35 AM | #6 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I'm having a similar problem which I haven't been able to diagnose. (14 FR-S) My OBD reading tells me that I'm only getting 80.1% absolute throttle. AFR when I give it WOT is 11.4. I have an ESC on my car but I don't think that's related. I cleaned the throttle body intake and the butterfly is positioned full open, but the car just doesn't feel as strong as it should. Not sure what to do next
11-14-2023, 09:46 AM | #7 | |
https://www.ft86club.com/forums/showthread.php?t=88069 |
11-14-2023, 05:26 PM | #8 |
for those who use an ESC, you'll know there's at is a two- position switch that most set at 60% and 80% throttle. That's what I did using my OBD reader. At that time it would also show 100% throttle when I floored it. The OBD was showing 100% absurd throttle, until I swapped out some new batteries for the ESC. I had run the car for a few hundred miles with the ESC turned off. That caused the batteries to go bad. Once I replaced the batteries and turned the ESC back on, I'm getting 80.1% ATP reading. Talked to the folks who make the OBD reader and they told me it's telling me what the ECU is telling it. I have a butterfly valve that's wide open and I'm wondering if there's something else in the throttle body assembly that's telling the car it's only supposed to get 80%.
Similar Threads | ||||
Noise on acceleration of a A/T car | alone1i | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 08-18-2020 03:03 AM |
Buddy Club Race Spec Coilover Problems on Problems on Problems | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 09-04-2016 11:18 PM |
Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 04:01 PM |
Does the A/C cut off upon hard acceleration? | brillo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 03-26-2013 09:31 AM |
Acceleration | Axel | Other Vehicles & General Automotive Discussions | 0 | 02-10-2010 06:56 PM |
