Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-09-2023, 09:13 AM | #1 |
Drives: GT86
Transmission leaking?
Is this leaking from the gasket?
Had this look towards the back of the transmission pan. Was told it was the gasket and had it replaced. About over a year later seeing the leaking again. It just seems to be around the back of the pan, could it really be the gasket again? As far as I can tell I don't see it coming from anywhere else. Just didn't expect the gasket to go bad again. |
08-09-2023, 11:30 AM | #2 |
Drives: 2016 Scion FRS Release Series 2#439
Are you confident the gasket was replaced? Looks like a bead of orange RTV along one edge.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) |
08-09-2023, 12:17 PM | #3 |
chicken tonight
Is there any fluid above the gasket line? If so, it's not the pan.
Most likely it was shoddy surface prep before applying the RTV.
08-09-2023, 01:18 PM | #4 | ||
Drives: GT86
I had this done at Toyota, was hoping they would have done a better job. |
08-09-2023, 02:27 PM | #5 |
chicken tonight
Bummer. Squeezing extra hard is only going to warp the pan or strip the threads. Pan seals are tricky because oil is constantly oozing/wicking down the inside surface of the upper component. It takes a long time for that to slow enough for the sealant to set before more contaminant gets into the joint.
If it was mine, I'd pull the pan, let the transmission drip onto a tray for a couple days, and only then clean really well. I don't know how the job could be done effectively in an hour.
08-09-2023, 04:44 PM | #6 | |
08-10-2023, 09:59 PM | #7 |
That much in a year, that is not a leak. Clean it up and move on with your life.
The Following User Says Thank You to Grady For This Useful Post: | Griever423 (08-17-2023) |
Similar Threads | ||||
Transmission lessons learned: (McLeod & FA24 transmission upgrade) | GrandSport | Tracking / Autocross / HPDE / Drifting | 7 | 07-15-2023 11:09 PM |
Oil Leaking?? | tonytduc | Issues | Warranty | Recalls / TSB | 371 | 11-13-2016 07:14 PM |
Oil leaking oil pan? | Astroboy | Engine, Exhaust, Transmission | 9 | 01-30-2015 03:32 PM |
Car leaking | davebrus | Issues | Warranty | Recalls / TSB | 4 | 03-21-2014 11:23 AM |
AT Transmission rear seal leaking. | CircuitJerk | Issues | Warranty | Recalls / TSB | 6 | 10-31-2013 03:41 PM |
