Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-31-2023, 10:33 PM | #1 |
friendly
Drives: 17' 86
Direct injection install
Hello!
Installed refreshed direct injectors from counterspacegarage. Install was easy, almost too easy? Manifold removal was not too bad and was my first time. Pulling the injectors didn't require much force. Here's where I am confused, I placed the new injectors (left in freezer overnight) on rails and went to seat them and planned on tightening bolts little by little evenly to get them fully seated. I applied a bit of pressure to line it up and get far enough in to get the bolts started. One side fully seated with ease and I pressed the other side in with ease. Same thing on both banks of the engine. Car started and seems to run well? Is it possible to see if I boinked the new seals since it seated unevenly or would it be evidenced in how well it is running? @CSG Mike
Seek comfort in discomfort.
05-31-2023, 11:44 PM | #2 |
chicken tonight
I haven't done this job but I'm guessing the freezer thing is to stiffen the seals so they don't ride up on the injectors when installing them. If that's the case, then it's important to seat the injectors quickly before the seals warm and soften.
06-01-2023, 12:18 AM | #3 | |
friendly
Drives: 17' 86
My concern is when putting the rail on they initially seated like this /_ instead of like = where the bottom straight line is the block. There was almost no resistance when seating .
06-01-2023, 02:54 AM | #4 | |
chicken tonight
I'll also stand by to hear from others who have actually done the work.
06-01-2023, 07:43 AM | #5 |
Drives: 2018 BRZ
Should be fine. I've unfortunately had to do this more than once but I didn't have to draw them in, they went in pretty easy. You'll know if you messed it up if you start hearing popping sounds.
The Following 2 Users Say Thank You to MICHAEL450f For This Useful Post: | alphasaur (06-01-2023), Ultramaroon (06-01-2023) |
06-01-2023, 07:56 AM | #6 |
Rust bucket enthusiast
It will be evident beyond a doubt if your seals are not sealing, sounds like your ports were relaxed and ready for love. Take the easy win and enjoy!
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post: |
06-01-2023, 08:41 AM | #7 |
Drives: 2013 frs base
When I did the DI install on 2013 FRS, they were very snug going in even after being in the freezer for a couple of hours.
Maybe CSG has a special, proprietary spit they use for lubricant. |
The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
06-01-2023, 07:03 PM | #8 |
Well this is certainly encouraging. I've been planning on doing this on my '13 soon.
06-02-2023, 08:41 AM | #9 | |
If it ain't broke, don't fix it. |
06-02-2023, 09:00 AM | #10 |
friendly
Drives: 17' 86
Mike from csg recommends it as preventative maintenance, IDK
The Following User Says Thank You to alphasaur For This Useful Post: | blsfrs (06-02-2023) |
06-02-2023, 09:57 AM | #11 |
06-08-2023, 06:24 PM | #12 |
My goal would be an injector cleaning service, seals would just be part of that.
The Following User Says Thank You to wheelhaus For This Useful Post: | Ultramaroon (06-08-2023) |
06-09-2023, 11:22 AM | #13 |
Before you pull them out, figure out where you are going to have them serviced. Not many shops do direct injectors. I sent mine to Injector Pulse in Chesapeake, Va. CSG offers DI cleaning. Unless there is someone in your area that does them, plan to be without your car for a while.
The Following User Says Thank You to blsfrs For This Useful Post: | wheelhaus (07-09-2023) |
06-09-2023, 09:07 PM | #14 |
Drives: 2017 BRZ w/PP
When I installed mine in my IAG block all i did was put a little bit of oil on it like the manual said and then popped them in with a wood block behind it.
The Following User Says Thank You to Breadman For This Useful Post: | wheelhaus (07-09-2023) |
Similar Threads | ||||
Direct injection | Rabrooks | Engine, Exhaust, Transmission | 3 | 11-01-2022 02:39 AM |
Direct injection/port injection explained? | mike the snake | Software Tuning | 31 | 06-06-2021 06:17 PM |
Another direct injection thread! Yay! | frscory | Forced Induction | 7 | 12-27-2018 03:47 PM |
Direct Injection Delete Kit | Carolina Dyno | Engine, Exhaust, Bolt-Ons | 4 | 06-26-2015 11:47 AM |
Gasoline Direct Injection... | DoogenBurns | Engine, Exhaust, Transmission | 5 | 05-21-2012 02:05 PM |
