Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
04-14-2023, 05:08 PM | #1 |
Drives: '17 BRZ PP
OEM Subwoofer with aftermarket head unit
Hi Guys,
I have the OEM sub with an aftermarket HU (Kenwood DMX9706S), and all stock speakers. After much EQ tweaking I'm still not getting sound quality and separation that I want, and I'm annoyed by the fact that the only way to control the sub is to change the front speakers settings. I'm wondering if anyone's found a way to decouple the front speakers from the subwoofer output, or if there's a good wiring diagram I can use to pull out the sub wires and splice them into RCA connectors to plug directly into the HU. Any advice? Thanks, Casp |
04-14-2023, 08:56 PM | #2 | |
Master Collaborator
If you're not too fond of the two rear speakers, you could disconnect them and then rewire the system to route the head units' rear speaker outputs as the subwoofer signal input instead of how it is currently set up. That way you can use the fader of the head unit to fade between the six front speakers and the subwoofer. Also, make sure all of your speakers are in phase relative to one another. |
04-15-2023, 05:41 PM | #3 |
ProCrastinationConsultant
the oem sub is a speaker-level input only, so you can't wire it in as a typical aftermarket audio amp. the above suggestion to take over one of the radio's speaker outputs is really going to be one of your only options if you want to keep all the gear as-is.
04-24-2023, 12:12 AM | #4 |
That sub is jumped from the speaker levels on the rear channels and you should be able to decouple it by just unplugging that jumper. The main issue will be finding an amplified output to connect it to.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue 1994 Ford Probe GT 5MT - Red(some would argue pink) 1969 Mustang Fastback 4MT - Royal Maroon |
04-24-2023, 07:53 PM | #5 | |
i haven't seen a diagram, but all '13-15's with the sub as an option had a door speaker amp in the front drivers side of the trunk. the harness jumped off of that, as the amp received a full range signal.
04-25-2023, 11:03 AM | #6 | |
Master Collaborator
Yeah, with that aftermarket head unit he's got in the dash, OP should now have a full frequency speaker-level signal to the rears, (depending on his setpoints in the head unit, of course) which should be sufficient for what he's wanting to do. Now if he'll just come back and heed the advice he asked for. |
The Following User Says Thank You to FR-S2GT86 For This Useful Post: | soundman98 (04-28-2023) |
05-01-2023, 07:31 PM | #7 |
Drives: '17 BRZ PP
Thanks for all the feedback guys! I'll look into finding a wiring diagram for the rears and go from there. Any places I should check out first?
Casp |
05-06-2023, 04:23 AM | #8 | |
Master Collaborator
Further advice, since you're new here, make sure to press the [QUOTE] button: when replying to someone on this thread so that the forum alerts us in the notification area at the top of the page: that you have replied, otherwise we will not know that you have done so unless we specifically open the thread to look. We can give a quicker reply back to you if you do in order to help you solve your issue. |
05-06-2023, 09:12 AM | #9 | |
then we create an inception situation with a quote-in-a-quote-in-a-quote-in-a-quote! i just hit 'new posts'. see it all just fine. this place moves at the right speed for me.
05-06-2023, 11:30 PM | #10 | |
Master Collaborator
Yeah, we all have our different ways of navigating the site. I just find it easiest to refresh any screen I might be on and look at the top of that page to see if there are any new alerts pertaining to quotes of mine made by others or thanks directed towards me. Tap that alert and it goes straight to the alert list page. Just easier for me when I'm in the middle of a conversation. |
The Following User Says Thank You to FR-S2GT86 For This Useful Post: | soundman98 (05-07-2023) |
Tags |
sound, speakers, subwoofer, wiring diagram |
Similar Threads | ||||
Connecting Subwoofer to the head unit BRZ 2020 | Teppka | Electronics | Audio | NAV | Infotainment | 1 | 06-17-2021 12:37 AM |
Help with aftermarket head unit | FR-Shred | Electronics | Audio | NAV | Infotainment | 25 | 05-06-2015 01:47 AM |
2014 FR-S Head Unit + Subwoofer | Rio | Electronics | Audio | NAV | Infotainment | 13 | 01-18-2014 01:36 AM |
BRZ Audio Overhaul - Subwoofer, Amp, Speakers, Head Unit Replacements | NeoMarine | Electronics | Audio | NAV | Infotainment | 4 | 10-18-2013 09:23 PM |
Which Aftermarket Head Unit to get ? | TRD_86 | Electronics | Audio | NAV | Infotainment | 9 | 10-10-2013 07:41 AM |
