Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
03-23-2023, 04:24 PM | #1 |
Drives: Scion frs salvage title now
Stability control issue. HELP!
Hi, so I have a 2013 scion FRS I track. In October I wrecked it and I got it back driving recently, but theres a problem with the stability control. When I take some corners at speeds I did before the accident (the car is planted not sliding out or even close to) the stability control will activate sporadically and make the car becomes unstable. My buddy in a mechanics trade program say it might be a yaw sensor, but I can't find anything about that anywhere. Does anyone have any idea what's going on?
(Edit) also it only really happens when doing sharper turns, so could it be a steering position sensor? I just don't wanna drop a ton of money on something that may not be the problem. Last edited by Bellzebubfrs; 03-23-2023 at 04:47 PM. |
03-23-2023, 05:47 PM | #2 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Both the Yaw sensor (internal to the ABS/ESC control unit) and the steering angle sensor can be re-initialized with a scan tool that has OEM-level access.
If there are no diagnostic trouble codes, that's an easy first step. |
03-23-2023, 06:24 PM | #3 | |
TRACKBREAD
What's far more likely is that your alignment is different from before the crash. Do you have a printout of the current alignment? Or from before the crash for that matter? |
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | soundman98 (03-23-2023) |
03-26-2023, 10:16 AM | #4 |
Drives: '13 BRZ TLM Spec
Re-calibrate the steering angle sensor!
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
Tags |
stability control |
Similar Threads | ||||
Traction Control & Vehicle Stability Control wires under the hood | lynngarcia | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 06-15-2022 11:05 AM |
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 01:48 PM |
Stability Control? | ashtray | BRZ First-Gen (2012+) -- General Topics | 27 | 01-24-2013 05:32 PM |
TPMS, LSD and Stability Control | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 11-05-2012 04:12 PM |
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) -- General Topics | 40 | 04-25-2012 11:20 AM |
