Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
01-17-2023, 03:46 AM | #1 |
Drives: 2014 FRS
So I went over a curb
The other night I went over a curb in a parking garage which I really couldn’t see with my window tint, but besides the point, I didn’t notice till today the fender actually shifted it seems up and slightly outward from what I can tell.
I’m wondering if you guys recommend anything on fixing this or if I should just take it to a body shop and see what they can do. How much do you guys think it’ll cost to repair through a body shop? I’m gonna look more at the damage tomorrow but I think I’ll be more careful turning corners in parking garages now |
01-17-2023, 06:47 AM | #2 |
Be Kind
Drives: 2020 86
The bottom mount for the fender is at the pinch weld. I bet if you crawl under your car, you'll see it's smashed up pretty good. Just my guess. Might be cheap but looking at the bow in the fender, probably not.
The Following 2 Users Say Thank You to Wally86 For This Useful Post: | Spuds (01-17-2023), x808drifter (01-18-2023) |
01-17-2023, 07:44 AM | #3 |
Take it apart and look for bent things. From there we can tell how much to fix.
The Following 3 Users Say Thank You to Grady For This Useful Post: |
01-17-2023, 07:58 AM | #4 |
Drives: '13 BRZ TLM Spec
Easy, there is a bracket on the fender that bolts to the body behind the door. See circle in pic, it's a 10mm bolt accessable in the door jam with the door open. Look there, and under the car directly below for bends. I'd bet both the bracket and the pinch weld are tweaked slightly.
Loosen the 10mm fender bracket bolt but don't remove it. If the pinch weld is bent adjust that first. You can use pliers, or a hammer to straighten the pinch weld. Use a towel, or block of wood to help protect the paint. Once the pinch weld is straight, then gently adjust the fender bracket to bring the fender back in line with the door. Once satisfied, retighten the bolt. Probably will take about 30 minutes to fix...or a body shop will charge you $300-$500
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following 12 Users Say Thank You to Opie For This Useful Post: | bcj (01-17-2023), Code Monkey (01-17-2023), dragoontwo (01-17-2023), FRSBRZGT86FAN (01-18-2023), jordan7831 (01-17-2023), norcalpb (01-17-2023), RToyo86 (01-19-2023), soundman98 (01-17-2023), Spuds (01-17-2023), Tcoat (01-17-2023), Wally86 (01-17-2023), x808drifter (01-18-2023) |
01-17-2023, 09:52 AM | #5 |
Drives: 2014 FRS
Ok yeah I saw that bracket yesterday so I’ll definitely mess with that and pinch weld. Definitely gonna do it myself cause I’m not paying a shop $500 to do a relatively easy job. Thanks for the feedback everyone!
The Following 3 Users Say Thank You to carson.frs For This Useful Post: |
01-17-2023, 06:12 PM | #6 |
The Dictater
Drives: '13 Red Scion FRS
Don't bend or stress the fender itself too much. The paint might crack. You might want to loosen the top bolts while you are messing with the fender.
Yes, this has happened to me.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
01-17-2023, 08:15 PM | #7 |
has a funny hat
Drives: 2014 BRZ Limited
The Following 4 Users Say Thank You to pope For This Useful Post: |
01-17-2023, 08:55 PM | #8 |
Drives: 2013 FR-S 6 spd in Halo
The Following 3 Users Say Thank You to Spairo For This Useful Post: |
01-17-2023, 09:26 PM | #9 |
The Following 2 Users Say Thank You to Grady For This Useful Post: | soundman98 (01-17-2023), x808drifter (01-18-2023) |
01-17-2023, 11:28 PM | #10 |
ProCrastinationConsultant
it only counts if someone screams
The Following User Says Thank You to soundman98 For This Useful Post: | x808drifter (01-18-2023) |
01-18-2023, 07:08 AM | #11 |
LMGTFY
Drives: 13 FRS, 91 Miata
01-18-2023, 07:12 AM | #12 | ||
+1 on fixing your tint, your tint must not be legal if you couldn't see a simple curb or you need more awareness when slow speed driving.Either way you having to fix it will be enough of a deterrent to avoid this next time. If you've got front windshield tint across the whole window you're already breaking the law and bringing unnecessary police attention to your vehicle. Windshield: Non-reflective tint is allowed above the manufacturer's AS-1 line or top 4 inches. Front Side windows: Must allow more than 35% of light in. Back Side windows: Any darkness can be used. Rear Window: Any darkness can be used. Source: https://www.tinting-laws.com/utah/ Copyright © Tinting-Laws.com
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Wally86 (01-18-2023) |
Similar Threads | ||||
Out of alignment after going over a curb:( | SamtheKorean | Issues | Warranty | Recalls / TSB | 5 | 03-24-2019 04:43 PM |
Went over curb | Sedated | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 10-24-2017 01:37 PM |
Curb hit | FRSure | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 03-31-2015 10:16 AM |
Hit a curb :( | aakash | New England | 0 | 10-14-2013 10:04 PM |
Hit a curb | Itssrayyxd | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 02-08-2013 10:09 PM |
