BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
11-24-2022, 08:15 AM | #1 |
Drives: 2023 brz limited 6mt red
Price friendly spare tire/hardware kit?
I tried searching on here. Anyone have the dealership/Subaru part number for mounting hardware and where to buy a spare donut tire wheel setup?
11-24-2022, 08:39 AM | #2 |
Drives: 2022 BRZ Premium, 1990 Miata
I bought a spare on eBay for 80.00 that was from a 2016 BRZ.
It fits the recess in the trunk cavity perfectly, and I have not found it necessary to bolt it down. It hasn’t shifted around, even under hard cornering. |
11-24-2022, 09:23 AM | #3 |
Auto wreckers usually almost give spares away.
The Following User Says Thank You to Tcoat For This Useful Post: | x808drifter (11-25-2022) |
11-25-2022, 08:17 AM | #4 |
Thank you both!
The Following User Says Thank You to vindiesel For This Useful Post: | Tcoat (11-25-2022) |
11-27-2022, 03:04 AM | #5 |
Drives: BRZ 2023
Not specific to PP or regular
Spare Tire Bolt : 901720002 Spare Tire Washer: 97047FG000 Performance specific parts PP Spare Wheel: 28151FE030 PP Spare Tire: 28121VA050 PP Spare Foam Insert: 95086CA070 PP Spare Foam Spacer: 97046CA000 Regular spare Spare Wheel: 28151FJ031 Spare Tire: <Still looking> Spare Foam Insert: 95086CA040 Spare Foam Spacer: 52153PA181 Be careful about buying a very old tire. And if you are planning to get big brake kit then get performance package wheel. I had wheel oddly placed once, bolt wasn't tight enough and I could hear it going over bump. So would definitely recommend the washer and bolt, I paid about $12 with tax. Wheel was 124 and then I had to buy tire which I got from tire rack. Subaru tires were pretty old that someone else ordered. |
The Following User Says Thank You to ruturaj001 For This Useful Post: | vindiesel (11-27-2022) |
11-27-2022, 05:14 PM | #6 | |
Drives: 2022 BRZ
11-29-2022, 07:29 PM | #7 | |
Drives: 2022 GR86
I have that BBK and went with a regular spare. If I get a flat front tire, my plan is to put a rear wheel/tire in the front, and the spare in the rear.
Follow the build thread for my GR86!
11-29-2022, 08:24 PM | #8 | |
Wheels for Brains
My GT barely clears with a 3mm spacer (under 1mm) |
11-29-2022, 08:42 PM | #9 |
Drives: BRZ 2023
Might not be a good idea to put donut in rear. May be just put full spare in trunk.
11-29-2022, 08:50 PM | #10 |
Drives: 2022 GR86
The issue is the barrel.
The B-M4 hits the barrel of quite a few wheels that fit PP Brembo without problems.
11-30-2022, 01:03 PM | #11 |
Drives: 2022 BRZ Premium manual
On eBay I was lucky and found a spare wheel/tire from a 2020 Impreza for $60. Same size as BRZ but there's a greater market supply of them. Got the bolt and washer from my local Subaru dealer.
The Following User Says Thank You to 22BRyanZ For This Useful Post: | vindiesel (12-02-2022) |
05-09-2023, 05:58 AM | #12 |
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
05-13-2023, 05:40 PM | #13 |
Just paid 130$ shipped wheel tire from older brz and Subaru parts online for bolt and washer to mount in truck. There is minimal Subarus in junkyard near me
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
05-14-2023, 07:13 PM | #14 |
The Following User Says Thank You to vindiesel For This Useful Post: | ZionsWrath (10-18-2023) |
Similar Threads | ||||
Performance Package spare tire vs. regular spare | JeremyR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 67 | 09-22-2022 09:36 PM |
WTB: Spare Tire | kanundrum | Want-To-Buy Requests | 2 | 11-15-2016 11:30 AM |
Replace Only 1 Tire? / Spare Tire Question | chermo12 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-28-2015 01:44 PM |
Custom full size spare friendly trunk | BE4VER | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-03-2014 12:53 PM |
