Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-30-2022, 09:34 PM | #1 |
Drives: 2013 FR-S 6 spd in Halo
Uneven Coloring on Brake Rotors
After my last track day, when I swapped out my track pads, I noticed that the front rotors had a distinct color band on them.
Does anyone have any thoughts on what this may indicate? Sent from my SM-G950U using Tapatalk |
08-30-2022, 11:56 PM | #2 |
ProCrastinationConsultant
looks like you've got the wrong front rotors and calipers.
but mad props for getting those installed for a square braking setup.
08-31-2022, 07:09 AM | #3 |
HA. I forgot that I took pics of the rears. When i had the fronts off, I didn't think to take pics. When I found similar discoloring on the rear, I took some pics.
I guess at my age, I shouldn't wait a week to finally post a question. Here is a pic of the front that I did take after the wheel was back on. Sent from my SM-G950U using Tapatalk |
The Following 2 Users Say Thank You to Spairo For This Useful Post: | soundman98 (08-31-2022), Ultramaroon (08-31-2022) |
08-31-2022, 10:22 AM | #4 |
Drives: Crapcan
It's uneven transfer layer. Don't know why though.
08-31-2022, 12:41 PM | #5 |
So an uneven transfer layer was one of my suspicions. What I do not know is what would affect the transfer layer and thus cause it to be uneven. One obvious (but not necessarily correct) suspicion would be that I am getting uneven brake pressure across the rotor. Any thoughts on what would cause that? I am going to put a straight edge on the rotors to make sure that they are flat. However, this pattern shows up on all 4 rotors and 4 un-flat (new word by me) rotors seems unlikely.
Thanks for any input. Sent from my SM-G950U using Tapatalk |
08-31-2022, 01:39 PM | #6 |
New pads on used rotors? Totally viable.
You ideally want new rotors with new pads, unless you know your rotors are flat. |
08-31-2022, 03:34 PM | #7 |
Currently, I am leaving the rotors on the car and swapping the pads between my track pads and my street pads.
08-31-2022, 04:04 PM | #8 |
Anti stance.
08-31-2022, 08:42 PM | #9 |
That I did not. I had not even considered that as a possible issue.
Is that a thing??? Sent from my SM-G950U using Tapatalk |
08-31-2022, 11:54 PM | #10 |
Thanks
I got better wear when I started doing pedal dance.
09-01-2022, 12:55 PM | #11 |
Drives: 2022 GR86 Premium Track bRed
I saw something similar when i bedded my track pads on the stock rear rotors (thanks tirerack - though they did do right just not in time). It was only on the one where i couldn't fit a shim between the pad and the caliper. Sanding the pad a little and installing a shim fixed it.
09-01-2022, 12:58 PM | #12 | |
AP racing posted a video of how to clean old material off then bed new on. basically a few stops from 50-5 mph should get them hot enough to burn off the old material, then repeat the normal bedding process |
09-01-2022, 03:10 PM | #13 |
Drives: Crapcan
I don’t think I would worry about it. My car looks about the same and the rotors have only had the same pads on them their entire life.
09-01-2022, 04:08 PM | #14 |
helmholtz resonator
Drives: '15 ultramarine
I always went by more how they worked. If working great, I don't care how they look.
Similar Threads | ||||
Uneven brake temperatures (Left to Right)? | imprezive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 05-02-2022 07:52 PM |
Uneven brake temps and warping after a light track day | imprezive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 04-21-2022 12:21 AM |
FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings | fc3s_johnny | Brakes, Suspension, Chassis | 11 | 10-05-2020 10:26 AM |
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
