Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-24-2022, 01:16 PM | #1 |
Drives: 2017 Toyota 86
Cicada/clicking sound after installing factionfab Rotors/pads
Hey all, I just installed brand new factionfab rotors(FFA1.10038.1)(FFA1.10037.1) and pads(1.10066.1)(1.10067.1) and it seems like I’m running into some noise issues. The noise only comes from the rear drivers side of the car. The best I can describe it as is a cicada/ clicking sound, I can hear it while driving not even braking. I’ve read the slotted rotors can make a similar sound but it doesn’t make sense to why it’s only on one rotor. I’ve had them all off 4 times to make sure everything is correct, cleaned etc.
06-24-2022, 07:40 PM | #2 |
ProCrastinationConsultant
could it be a wheel bearing?
06-24-2022, 11:31 PM | #3 |
I don’t think so, the sound started right after doing the brakes and I did check to see if the wheel had play in it. I’m stumped.
06-25-2022, 11:06 AM | #4 |
can you hang the caliper up and off the brake disc on the car safely, and then roll forward 20 feet? that would eliminate 1 of the options.
06-25-2022, 12:32 PM | #5 | |
Lift the rear take it off and spin it by hand or start the engine and put it in gear if you want to try this OP. Idk what the solution is, video would help a lot. |
The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (06-27-2022) |
06-27-2022, 09:56 AM | #6 |
Did you clean/lube the slider pins on all the calipers? The one corner might be sticking slightly and dragging.
06-27-2022, 10:27 AM | #7 |
The Following 2 Users Say Thank You to Keegster55 For This Useful Post: | soundman98 (06-27-2022), strat61caster (06-27-2022) |
06-27-2022, 10:28 AM | #8 |
06-28-2022, 10:27 AM | #9 |
Drives: 2014 GT86
Might be that you accidentally bent tin guard and now it's screeching?
Similar Threads | ||||
Clicking sound above 2k RPM - helpppp | slyphen | Issues | Warranty | Recalls / TSB | 6 | 09-10-2019 08:11 PM |
Clicking sound on startup | radroach | Issues | Warranty | Recalls / TSB | 2 | 01-17-2019 06:55 PM |
FRS Clicking/Tapping sound | DCStorm | Issues | Warranty | Recalls / TSB | 30 | 12-29-2017 09:59 AM |
clicking sound? | FR-Sky | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 11-26-2016 09:21 PM |
Clicking sound when shifting into 4th? | Marcbrz86 | BRZ First-Gen (2012+) -- General Topics | 4 | 05-19-2015 08:52 PM |
