Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-03-2022, 04:56 PM | #1 |
Drives: '13 FR-S Ultramarine
Lugnuts rusting and falling apart?
I've had two or three lug nuts completely rust and break apart. Today I took my car in to get a tire rotation and one of them broke in a weird way (not rust, just the metal broke on top) to where they can't even take it off. What is going on? The thing lives in a garage!
Also, how the hell are they going to get this off? |
06-03-2022, 05:23 PM | #2 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
In a sense you are lucky - if you can get the other 4 off (or break them in a similar way) you can get the wheel off and tap out what's left of the stud. Replace with a new stud and you are ready to roll again.
Chances are during the previous tire rotation the lug nut was cross-threaded. |
The Following 3 Users Say Thank You to 2020BRZtS For This Useful Post: |
06-03-2022, 05:27 PM | #3 |
None of your studs would have broke from the little surface rust they may have had. They would not rust through short of several decades parked in a field and even then they would seize before breaking.
The most common reason to break lugs is to over torque them or side load when removing the nuts. That break looks like side loading (uneven pressure on the wrench).
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | DarkPira7e (06-05-2022), Opie (06-08-2022) |
06-03-2022, 05:39 PM | #4 |
Hmm. So I should have pointed the finger back at discount tire since they are the only ones who have touched the tires since I got it in 2013. Sigh. Ok, off to be mean to someone.
The Following User Says Thank You to lynnmichelle For This Useful Post: | alphasaur (06-06-2022) |
06-03-2022, 05:46 PM | #5 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Appears to be a whole lot of uga duga's going on there. I'd be willing to bet those wheels get put on with an impact, probably never seen a torque wrench.
The Following 4 Users Say Thank You to BirdTRD For This Useful Post: |
06-03-2022, 08:44 PM | #6 |
ProCrastinationConsultant
the lugs just sometimes break on these cars.
i've been the only one that's ever done anything with the wheels on my car. i've never used an impact. always a 4-cross wrench, by hand. i've broken 3 lug studs. fortunately, all in the front, where they're somewhat easy to change.
The Following User Says Thank You to soundman98 For This Useful Post: | EAGLE5 (06-18-2022) |
06-03-2022, 08:44 PM | #7 |
06-03-2022, 09:03 PM | #8 | |
06-03-2022, 09:56 PM | #9 | |
The 4 cross wrench is horrible for breaking studs. The leverage created by having the cross bar so far from the nut give so much side shear pressure that no matter how careful you are you can snap a stud in a heartbeat. I pitched my cross wrench in the scrap pile in about 1975 and switched to a Johnson bar with a long socket. Never broke a stud again.
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
06-03-2022, 09:58 PM | #10 |
AutoX-10/10ths every run
Most probably over torqued. I did a lot of wheel changes on the factory studs on my 2013 while using a torque wrench and never had one break. I also used anti-seize lube on my studs. Lots of debate can be had on if you need anti-seize, but it worked for me.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
06-03-2022, 11:43 PM | #11 | |
i've got a big impact i use for work, was just trying to avoid excessive force by using the 4-cross. not opposed to doing things differently though. i hate having to change studs. it's just weird to me though. this is the only vehicle i've ever broken studs on, used the same technique on my ford, mitsubishi, and chrysler of the past. well, the chrysler had an issue with seized lug nuts, but that was specifically because i was a dummy that changed the stock lugs for fancy colored aluminum anodized versions, and then subjected dissimilar metals to salt...
The Following User Says Thank You to soundman98 For This Useful Post: | Tcoat (06-04-2022) |
06-04-2022, 12:02 AM | #12 | |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
The Following 2 Users Say Thank You to villainous_frx For This Useful Post: | soundman98 (06-04-2022), Tcoat (06-04-2022) |
06-04-2022, 12:21 AM | #13 | |
The 4 cross was needed back in the day when wheels were often set several inches back into the fender and the reach was a necessary evil.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | soundman98 (06-04-2022), villainous_frx (06-04-2022) |
06-04-2022, 12:33 AM | #14 | |
Ya there is nothing at all wrong with using an impact as long as the nut is not even slightly cross threaded (which is almost guaranteed to happen when people slap the nut in the socket and go to town) or they run it up to full speed until it is forced to stop.
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (06-04-2022) |
Similar Threads | ||||
Interior trim falling apart | SeanTP | Issues | Warranty | Recalls / TSB | 6 | 05-09-2017 01:22 PM |
5 axis trunk lip falling off? | Decimus | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 01-04-2015 10:10 PM |
RE-11's falling off after being heated up? | Silver Ignition | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 10-01-2014 11:22 AM |
Rusting | kalamitykode | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 05-19-2014 09:04 AM |
The ride of the falling leaves | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 10-20-2011 06:45 PM |
