Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-02-2022, 10:05 PM | #1 |
Drives: 2016 scion frs
Positive battery terminal damage
Hello,
So i had some start up issues that pointed to a dead battery but battery is at full capacity. Anyways, i seem to have snapped off this part of the positive battery terminal uhh thing. Anyways to fix this without replacing the whole battery wire harness? Or know the small part that touches the white part? Trying to look online to see if i cant just get that part but im not sure what its called. |
06-02-2022, 10:33 PM | #2 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
search for battery cable lug or ring terminal and you'll find something you can use. It may become a larger project or cost prohibitive if you don't have the tool or you have to cut that one off and don't have enough length.
The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post: | jrhudson (06-03-2022), Ultramaroon (06-03-2022) |
06-02-2022, 10:56 PM | #3 |
Totaled, time to part out.
Your choices are to repair or replace. You can cut that one off to avoid shortening the harness. As above find any battery terminal end. If you do not have access to a swedger you can solder but that is not the preferred method for battery terminals. |
06-03-2022, 02:08 AM | #4 |
I found the whole battery harness for $45 on ebay so if i need i could just get that.
The Following User Says Thank You to jrhudson For This Useful Post: | Opie (06-03-2022) |
06-03-2022, 02:16 AM | #5 |
Bubba says to lay a piece of metal under both pieces and weld it all together.
Then, be careful with it - |
06-03-2022, 02:19 AM | #6 |
06-03-2022, 02:23 AM | #7 |
The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post: | humfrz (06-03-2022), Ultramaroon (06-03-2022) |
06-03-2022, 02:25 AM | #8 | |
chicken tonight
06-03-2022, 02:46 AM | #9 |
Bubba here - sorry to be late to the party.
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
06-03-2022, 07:19 AM | #10 |
Drives: hyper blue
Knipex makes a nice double crimp tool but it isn't cheap.
We need more lead in our brass. |
06-03-2022, 03:54 PM | #11 |
...okay so i realized i bought the wrong thing. The terminal that broke was actually on the side coming from the fuse box. ugh have to get those battery terminal things for the positive side. This is annoying.
06-03-2022, 04:07 PM | #12 |
chicken tonight
Bubba's fix is looking pretty good right now.
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (06-04-2022) |
06-03-2022, 04:33 PM | #13 |
I rather solder or weld it but i dont have a welder or anything like that.
Temporary solution until my terminals get here. Works! |
06-03-2022, 07:20 PM | #14 |
chicken tonight
Would take a big-ass soldering iron/gun to get enough heat into that cable but, honestly, it's what I would do. Heat shrink is a pro move.
Similar Threads | ||||
Part number for fusible link block on positive battery terminal? | Jack Black | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 08-24-2022 08:58 AM |
Battery terminal covers | 2017BRZ4ME | BRZ First-Gen (2012+) -- General Topics | 21 | 04-27-2020 12:04 AM |
Battery Brace touched Positive Battery terminal, car won't start!! | 7m28 | Issues | Warranty | Recalls / TSB | 21 | 09-24-2017 12:55 PM |
Battery terminal setup | fuddbutter | Electronics | Audio | NAV | Infotainment | 0 | 01-24-2017 04:27 PM |
Lost my battery terminal nut. | qqzj | BRZ First-Gen (2012+) -- General Topics | 3 | 08-05-2014 07:51 AM |
