GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
03-11-2022, 01:02 PM | #1 |
Drives: gr86
Dont replace your GR86 premuim\BRZ Limited Headunit until you read this.....
There are a few car settings I can't seem to find other then on the cars head-unit..... Headlight control happens to be one of them, if you swap out the head unit you will lose that functionality, along with others ( I believe there is 2 other car settings), anyone find these settings on the dash cluster or anywhere else?
If that's the case then an aftermarket head-unit for the premium is out of the question. |
03-11-2022, 02:32 PM | #2 |
Drives: 2017 Hot Lava 86
What type of control do you need with the headlights other than on/off? Which I would hope would be on a steering wheel stalk.
03-11-2022, 02:52 PM | #3 |
Drives: gr86
03-11-2022, 03:03 PM | #4 |
I imagine that without the headunit the lights would just point forward like I would want them. Good to know. It’s stupid that it’s in the head unit, but I’d also hate to have some extra knob or whatever it would be on the dash. (not really sure what part of that system is controllable)
The Following User Says Thank You to Ebush For This Useful Post: | Master Jedi (03-11-2022) |
03-11-2022, 03:21 PM | #5 |
Drives: 2022 GR86
It is in the cluster in Canada, its called SRH and there is a toggle for on/off in both the cluster and headunit. I didn't find any non-media settings within the headunit that were not also in the cluster when I played with the settings.
The Following 2 Users Say Thank You to Rustyoid For This Useful Post: | DylanJZA (05-16-2022), Master Jedi (03-11-2022) |
03-11-2022, 03:27 PM | #6 |
Drives: 1996 Turbo Miata
This only pertains to the AT Premiums, MT Premiums do not have the adaptive headlights.
03-11-2022, 03:46 PM | #7 |
Drives: 22 BRZ limited
03-11-2022, 04:20 PM | #8 |
Drives: gr86
03-11-2022, 04:21 PM | #9 |
Drives: gr86
03-11-2022, 04:33 PM | #10 |
Drives: '22 BRZ
Would it be possible to change these setting with an OBD scanner and proper software?
03-11-2022, 08:54 PM | #11 |
Drives: 22’ Red GR86 MT Premium
On mine I was able to change the SRH On/Off via the steering wheel controls. M/T Premium
The Following 4 Users Say Thank You to jimmyjazz86 For This Useful Post: |
03-13-2022, 04:44 PM | #12 |
Drives: '22 BRZ 6MT MGM
Yeah, these settings are available in the gauge cluster controls. You can still replace the head unit without loss of functionality (I think the Starlink UI might be a questionable one here though).
The Following 2 Users Say Thank You to shoreline86 For This Useful Post: | DylanJZA (05-16-2022), Master Jedi (03-14-2022) |
03-14-2022, 02:25 PM | #13 |
Drives: gr86
Awesome! thanks!
03-23-2022, 11:57 AM | #14 |
Drives: 2013 Black FR-S
The shift light indicator controls are only set via the head unit.
The Following User Says Thank You to sw20kosh For This Useful Post: | Yoshoobaroo (03-23-2022) |
Similar Threads | ||||
BRZ Limited Headunit w/NAV | Swallace113 | Audio/Visual, Electronics, Infotainment, NAV | 1 | 07-09-2018 06:09 PM |
ISO! Good headunit to replace bspoke | ThisGuyTaylor | Want-To-Buy Requests | 1 | 03-14-2018 07:34 AM |
Replace '16 BRZ Limited Fog Lights with LEDs | bobka7914 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 02-09-2016 02:03 PM |
SOLD---FS: BRZ Limited NAV Headunit | BRZ_HaVoKx | Audio/Visual, Electronics, Infotainment, NAV | 11 | 03-15-2014 12:31 AM |
FS: BRZ Limited NAV Headunit | BRZ_HaVoKx | Miscellaneous | 5 | 02-17-2014 06:26 PM |
