Old 12-27-2021, 11:35 AM   #1
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Sizing help on buying new set of wheels
Currently, i have some Enkis T6S 18x8 wrapped on some Pilot sports 4s for summer setup. Idk what the weight is on that wheel and size combo, but the car drives fine on the street and on track with that set up.
Im planing on buying Gramlights 57xtreme 18x9.5 with the pilot sports 4s.
Since Gramlights wheels are wider, they should weight a bit more than my enkies. My question is would i feel the different when driving on this bigger set up? Or gramlights are 'lighter' than usual and i can get away with the weight
Although the car is on stage 2+ and it feels better than stock, i don't want to make this car slower than it already is.
Jfheisenberg is offline   Reply With Quote
Old 12-27-2021, 11:50 AM   #2
meWant
Drives: '16 BRZ Limited
Based on a few quick searches, the enkei t6s that you currently have weigh about 21.5lbs/wheel whereas the gramlights would weigh about 21lbs/wheel.
So if the tire size is going to be the same, then they should feel pretty much the same.
Enkei T6S
GramLights 57Xtreme
meWant is offline   Reply With Quote
Old 12-27-2021, 01:52 PM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
What size tires are you planning on using
Old 12-27-2021, 02:24 PM   #4
Jfheisenberg
Enkei T6S
GramLights 57Xtreme
Yea looks like the weight is very similar, just wondering if im going to feel any downside with a wider wheel/tire
Pilot Sport 4 S 245/40ZR18
Old 12-27-2021, 02:45 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yes the inertia will be higher. Wether you’ll feel the difference or not is debatable, hard to say without trying it since not everyone is as sensitive to it.
Old 12-27-2021, 04:06 PM   #6
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
I reckon the 245/40 tyres (and associated increase in rolling diameter over stock) would make more difference to the feel of the car than the wheel change. 40 profile is far too big, that’s over 12mm gain in ride height. 245/35 is near identical to stock, 255/35 is slightly larger, but still much closer than 245/40.
ACT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to ACT86 For This Useful Post:
Jfheisenberg (12-28-2021), Wally86 (01-11-2022)
Old 12-27-2021, 05:45 PM   #7
TommyW
TommyW's Avatar
Depending on offset you may need spacers in the front
Old 12-28-2021, 03:45 PM   #8
Jfheisenberg
Maybe i should reconsider and go with 17x9 gramlights instead. I like how the 18x9.5 looks, but knowing that i track the car maybe i should stay with a smaller / lighter wheel.
The Following User Says Thank You to Jfheisenberg For This Useful Post:
ACT86 (12-29-2021)
Old 12-29-2021, 10:28 AM   #9
Vital
Drives: 2015 BRZ
If you track then yes 17x9 is the way to go and they will weigh less than the 18x9.5 wheels. Not mention "Gramlights" really aren't even all that "light weight". Look into Konig wheels their FlowFormed wheels are a good price, just a suggestion.
Vital is offline   Reply With Quote
Old 12-30-2021, 12:40 PM   #10
Jfheisenberg
What do you guys think about pilot sorts 4 all season tire? Currently I swap wheel/tire set for summer and winter and been considering having just 1 set as i dont drive the car much.
Any experience with that tire on track/sprinted drives?
Old 01-11-2022, 08:56 AM   #11
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
If weight is your concern, try looking at WedsSport TC105X. For 18x8.5 +43, it only weighs 16.42 lbs!
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 03-11-2022, 01:21 AM   #12
The Count
Drives: 2020 Toyota 86 Manual - Autox Drift
Is +25 mm the biggest we can go in front with stock wheels and tires? Is there a list on max negative offset for different size wheels?
The Count is offline   Reply With Quote
Old 03-11-2022, 01:47 AM   #13
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
See the 1st gen Wheel Directory: https://www.ft86club.com/forums/showthread.php?t=7535
EndlessAzure is offline   Reply With Quote
plus 1 wheels, tire sizing question soundman98 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-21-2019 05:29 PM
Advice for buying used wheels? slow and serious Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-24-2019 07:31 PM
Work Wheels.. Disk sizing ? Juvenile Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 05-11-2016 04:40 PM
Buying Wheels 5150 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-20-2016 05:00 AM
Concerns on dual bore sizing of wheels? Barry Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-15-2014 02:02 PM
