Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
08-16-2012, 03:49 PM | #1 |
Drives: Hot Lava A/T
audio varies
Hi all,
I've had my car a couple months but I've just noticed something the past couple weeks. When I turn on the stereo and select what station to listen to, the volume level is kinda low, then after about 5 seconds, it increases significantly. After the initial increase, it does not vary. This has caught me off guard a few times as I manually increase the volume and then it gets too loud a few seconds later and I have to lower it manually. Anyone else notice this or has my stereo become haunted? |
08-16-2012, 03:56 PM | #2 | |
Drives: 2013 Subaru BRZ 6MT Limited WRB
08-16-2012, 04:26 PM | #3 |
Most likely hd, just watch the display when it happens. The stereo also has auto sound leveling based on noise which you can adjust for , its in the stereo manual.
Sent from my PH44100 using Tapatalk 2 |
08-16-2012, 06:24 PM | #4 |
Drives: Nevermorange FRS
It's the HD radio. Picks up the non-HD station first then once the HD signal is detected it transitions and poof, there's your difference. You didn't notice it sounds significantly better after that happens right?
08-16-2012, 06:40 PM | #5 |
You guys are correct - it was the HD setting. I tried it both ways and it only does this when HD is 'on'.
Thanks. |
Similar Threads | ||||
My audio build - Pic Heavy | rmjjensen | Electronics | Audio | NAV | Infotainment | 41 | 10-10-2016 10:03 AM |
Looking for an FRS/BRZ in the SE For Audio | SpeakBeck | Southeast | 8 | 02-17-2013 12:57 PM |
BRZ Audio Question | poudre | Electronics | Audio | NAV | Infotainment | 4 | 07-11-2012 08:48 AM |
New Audio system going in | Jordan6908 | Electronics | Audio | NAV | Infotainment | 20 | 06-25-2012 02:12 PM |
Audio Options? | SpeakBeck | Electronics | Audio | NAV | Infotainment | 13 | 06-04-2012 01:06 AM |
