Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
11-30-2021, 03:38 PM | #1 |
Drives: AE86, AP1
stock clutch alternatives?
Looking for stock clutch replacement. I know Exedy makes a bunch of OEM clutches. I know Aisin is in part owned by Toyota. Any reason to go with one brand over another other than price/OEM-ness?
Aisin CKT078 is $185, includes PP, Disc, TOB and Pilot Bearing Exedy FJK1005 = $225, includes PP, Disc, TOB and Pilot Bearing OEM Toyota: PP - SU00300800 - $185, disc - SU00300799 - $100, TOB - SU00307349 - $20 Total = $305 Exedy 15806 = $400, Organic, “Stage 1” includes PP, Disc, TOB and Pilot Bearing. I honestly have no idea what “Stage 1” implies. I understand that the TOB was an issue and Toyota issued a TSB along with a revised TOB. Is the new Toyota TOB good? Any inputs regarding the other brands? Other quality brands like NTN, SKF? |
11-30-2021, 03:47 PM | #2 |
Drives: Subaru BRZ
Hey, I can only go off experience but I have an Exedy 'heavy duty' clutch kit in mine (Stage 1 I assume). I was told it uses a WRX pressure plate.
I have done many hillclimbs since then with many runs at each event, very hard launches in the dry (on soft semi slicks) and much feathering in the wet, and have had no issues whatsoever. Sent from my SM-G973F using Tapatalk |
11-30-2021, 04:19 PM | #3 |
Drives: 2013 frs base
Get a better fork and pivot while you're at it.
11-30-2021, 04:37 PM | #4 |
Drives: Subaru BRZ
I've heard this before. What's the issue? What does it change?
11-30-2021, 09:50 PM | #5 |
Drives: 2014 GT86
Adds insurance that they'll not break or bend (more needed for stiff aftermarket clutches for high power outpus though). And as changing them also involves dropping transmission, worth doing at same time. For same reason people usually change throwout bearing at any gearbox dropping work, even if old still works fine.
12-01-2021, 12:38 AM | #7 | |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
12-01-2021, 05:56 AM | #8 |
Drives: '15 BRZ RA
I changed the clutch lately and changed the throw out bearing with the newer one. I would suggest to stay with the factory clutch, unless you have a much higher power output..
12-14-2021, 02:01 AM | #9 | |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I bumped it up when I got my HKS supercharger. Actually, I lucked out a bit, the TOB failed before the supercharger arrived as it took 5 months to ship. Only regret was the extra ticket punch on the wallet. Glad I went to a stage 2 though, this SC has shown itself to break the rear loose in the rain sometimes pulling hard in second hit 6k plus on my Advan all seasons. Good tires, but once you feel summer tire grip, no all season feels worth a darn. Last edited by jeepmor; 12-14-2021 at 02:13 AM. |
12-14-2021, 10:46 AM | #10 |
Drives: '13 Whiteout
Exedy clutch
New TOB Verus pivot/fork |
The Following User Says Thank You to TommyW For This Useful Post: | e_lunatic (11-11-2023) |
12-23-2021, 08:26 PM | #11 |
Ultra Senior Member
Drives: 2014 BRZ Premium, WRB
If you’re planning to keep the car for any significant period of time after you change the clutch, definitely upgrade your clutch fork. This is what happened to mine (scroll almost to the bottom). It’s apparently a fairly common occurrence.
https://www.ft86club.com/forums/show...=144856&page=2 |
The Following User Says Thank You to vfrqqq For This Useful Post: | blsfrs (12-23-2021) |
12-24-2021, 03:45 PM | #12 |
Make sure you get a clutch alignment tool with your kit. I forgot that when getting oe parts and luckily had access to a machinist who owed my dad a favor so I was only down an extra day or two.
For that alone I'd go with exedy or aisin for your first clutch, if you hang onto the tool the next clutch/pp can be OEM parts assuming it's not got crazy power. For that alone it's probably worth getting the exedy or aisin. |
12-31-2021, 12:52 AM | #13 |
Drives: 2015 FR-S
I think gen2 stock clutch package is actually a really good gen1 "Stage2" equivalent. Now that we know gen2 makes roughly 240-245 BHP based on dynos.
The prices on gen2 clutch is also roughly commensurate with "stage2" Parts.subaru.com lists them at ~2x the cost as gen1 clutch packs. For anyone with FI its a good alternative that ppl can consider that's also OEM. The flywheel looks to have the same bolt pattern but someone will need to confirm. gen 2 Clutch $451. gen 1 clutch $210 gen 2 Pressure plate $355. gen 1 pressure plate $190 Last edited by FrickingReallySlow; 12-31-2021 at 01:14 AM. |
The Following User Says Thank You to FrickingReallySlow For This Useful Post: | RedReplicant (12-04-2022) |
01-01-2022, 06:51 PM | #14 |
Ulli
Drives: Toyota GT86
I also had the problem with the series release lever on the series thrust bearing
I upgraded to a hydraulic bearing from Sachs Motorsport and the standard lever. the series clutch worked well, today i'm racing with a sequential gearbox https://www.ft86club.com/forums/atta...1&d=1641080925 Attachment 208449 |
Similar Threads | ||||
If my stock clutch is about to go out should I replace it with a stock or a stage 1? | Bread1 | Engine, Exhaust, Transmission | 6 | 01-28-2018 01:24 AM |
FS: Stock brake lines, stock clutch line, stock motor mounts | Agent_D | Brakes, Suspension, Chassis | 4 | 08-22-2017 12:24 PM |
ACT clutch and LWF or stock clutch and Evolution industries LWF | Hawk77FT | Engine, Exhaust, Transmission | 13 | 12-21-2014 02:14 AM |
86 Alternatives ??? | H8R GTS | AUSTRALIA | 33 | 09-05-2012 12:59 AM |
Nav alternatives? | Sport-Tech | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 04-13-2012 04:27 PM |
