Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
08-23-2021, 10:21 AM | #1 |
Financial Distress
Drives: 2017 GT86 325WHP
Right turn signal dims out a bit
I currently run TOMs tail lights with stock BRZ (2013) headlights that have an LED turn signal mod on them. The flasher relay I currently use is a DiodeDynamics tap-turn module.
It's been fine for 2 years but lately when using the turn signals, the right one would go on normally then dim for a split second, at first I thought it was my tail light bulbs, but the front is doing it too as well as the lamp on the cluster. There is no hyperflashing, just slight dimming when the signal comes on. This issue doesn't happen when the hazards are on which is what led me to believe it's not a bulb issue. Any advice is appreciated here, thanks! |
The Following User Says Thank You to scottryan For This Useful Post: | humfrz (08-23-2021) |
08-23-2021, 02:26 PM | #2 | |
The Following User Says Thank You to humfrz For This Useful Post: | scottryan (08-29-2021) |
08-23-2021, 08:17 PM | #3 |
ProCrastinationConsultant
i would pick up a replacement led flasher first-- easiest to replace, and if it's front/back, the most likely culprit.
The Following User Says Thank You to soundman98 For This Useful Post: | scottryan (08-29-2021) |
08-29-2021, 06:38 PM | #4 |
Financial Distress
Similar Threads | ||||
Turn signal cancelling/turn off issue | Koi | Issues | Warranty | Recalls / TSB | 5 | 10-18-2020 10:19 PM |
Right side turn signal does not turn on | Feargt86 | Issues | Warranty | Recalls / TSB | 4 | 10-02-2018 01:10 PM |
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! | Diode Dynamics | Exterior Parts - Lighting | 192 | 10-04-2017 11:51 AM |
Installed Third Brakelight Kit, Clock Completely Dims / Airbag Slightly Dims | FR-S Matt | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 01-26-2016 02:37 PM |
