Old 08-17-2021, 07:54 PM   #1
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Left turns feels like rear camber is changing?
This is weird. At moderate to fast speeds turning left, mid-turn it feels like the rear wants to step out (right).
Turn in, car takes a set. Then suddenly, the rear wants to wash out.
I’m getting my track alignment redone tomorrow. But I’m concerned that something is worn out, or is sticking, then breaking free (spherical joint on the racer x sway bar end links?).
Does this sound familiar to anyone? Can bad toe in rear alignment cause this?
It isn’t reproducible Turning right. Very high speed at the bottom Valkyrie hill at ORP counter clockwise was no problem 2 Sundays ago.
Four_wheel_drifts is offline   Reply With Quote
Old 08-17-2021, 09:18 PM   #2
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
Definitely sounds like a toe problem. You’re alignment guy will tell you right away. Does it behave oddly under braking vs accelerating?
BlueWhelan is offline   Reply With Quote
The Following User Says Thank You to BlueWhelan For This Useful Post:
Four_wheel_drifts (08-17-2021)
Old 08-17-2021, 09:24 PM   #3
Purist
Purist's Avatar
Drives: Subaru BRZ
Maybe get your ball joints checked. I had a bad one and the car would feel like the suspension geometry changed mid-corner. VSC light would activate too. We felt like it was steering from the rear and looked for issues with the rear, not the case.
The ball joint could explain the left turn only nature as well.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
Old 08-17-2021, 09:41 PM   #4
Four_wheel_drifts
[QUOTE=BlueWhelan;3457386]Definitely sounds like a toe problem. You’re alignment guy will tell you right away. Does it behave oddly under braking vs accelerating?
I haven't noticed it much under braking. Accelerating, yes, as I think about it.
Old 08-17-2021, 09:45 PM   #5
Four_wheel_drifts
[QUOTE=Purist;3457390]Maybe get your ball joints checked. I had a bad one and the car would feel like the suspension geometry changed mid-corner. VSC light would activate too. We felt like it was steering from the rear and looked for issues with the rear, not the case.
Front ball joint?
The behavior your describing sure sounds like it. I run with the predecessor to the trac box all the times, so my VSC light never comes on.
Old 08-17-2021, 11:35 PM   #6
Purist
Purist's Avatar
Drives: Subaru BRZ
[QUOTE=Four_wheel_drifts;3457402]
Front ball joint?
Front ball joint. It was wobbly loose. Damaged in an incident on track, went unnoticed and got worse over time. Started out feeling like severe bump steer. I guess it was changing the toe by many degrees mid-corner.
Side point for the younger players: When your car doesn't feel right, get it checked. Could've ended very badly for me.
Less More
Four_wheel_drifts (08-18-2021)
Old 08-18-2021, 12:34 AM   #7
Four_wheel_drifts
Purist: Side point for the younger players: When your car doesn't feel right, get it checked. Could've ended very badly for me
Totally! Turns out the 22mm nut on aftermarket rear toe link was loose. When I was under the car, I didn’t have enough leverage on my own to move the suspension. Once I got a helper to grab and shake the wheel back and forth with me under the car, it became obvious.
I check many nuts and bolts back there before every track weekend, but not those. ANOTHER point on the check list.
Thanks for your help, guys.
P.S. I checked the front ball joints first. They are tight.
Old 08-18-2021, 03:59 AM   #8
Purist
Purist's Avatar
Drives: Subaru BRZ
Glad you got it sorted.
Because community
Less More
Traction control turns on crazy when turnin left but not right? Nah Issues | Warranty | Recalls / TSB 58 09-13-2020 02:57 PM
Popping/creaking noise in hard left turns TheLaughingMan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 09-20-2019 05:01 PM
car feels funny after changing to summer tire/wheels theman233 Issues | Warranty | Recalls / TSB 4 04-02-2017 01:48 AM
Humming noise on left turns. kphan Issues | Warranty | Recalls / TSB 10 10-27-2016 11:49 AM
New front sway, a little unstable on left turns loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-20-2015 07:38 PM
