Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-04-2021, 04:43 PM | #1 |
Drives: '17 BRZ / CBS + PP
BRZ Brembo rotor interchangable with STI Brembo?
I've got 71k miles on my car ('17 BRZ w/PP), and the original stock pads are finally calling it quits. I'm planning to replace rotors as well, but I'm having trouble finding a set of stock blanks (not cross drilled or slotted) for the BRZ.
Subaru wants over $400 per rotor! And I've already been shipped the wrong parts, twice (claimed they were Brembo fitment). Does anyone have a good source for aftermarket blanks? If not, are the stock '04 5x100 STI rear rotors compatible with the BRZ? I know the calipers and bolt pattern will work, but I'm concerned about the parking brake. |
08-04-2021, 05:01 PM | #2 |
Try Counterspace Garage, a vendor on here.
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | LatentWagen (08-05-2021) |
08-04-2021, 05:07 PM | #3 |
Drives: '13 BRZ Limited
You asking about a specific vendor or part numbers?
For part numbers, did you see the list here? : https://www.ft86club.com/forums/showthread.php?t=144662 |
The Following User Says Thank You to 86league For This Useful Post: | LatentWagen (08-05-2021) |
08-04-2021, 11:35 PM | #4 |
Drives: 2022 GR86
Have you tried Centric blanks mentioned on the other thread?
The Following User Says Thank You to timurrrr For This Useful Post: | LatentWagen (08-05-2021) |
08-05-2021, 08:28 AM | #5 |
Thanks for the replies. That Everything we know thread was where I should've started!
The Following User Says Thank You to LatentWagen For This Useful Post: | timurrrr (08-05-2021) |
Similar Threads | ||||
PP Brembo front rotor weight, lighter-weight alternatives? | ZDan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 02-14-2022 07:03 PM |
08+ STI rear Brembo caliper and rotor question | Teratorry | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-20-2020 02:42 AM |
Brembo club racer BBK with 332mm rotor on 17 inch wheel? | GrabTheWheel | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 09-30-2019 02:04 PM |
FS: Brembo Rear Brake + Stoptech Slot Rotor Sold(local pick up /Ship fee) | andy86 | Brakes, Suspension, Chassis | 10 | 02-26-2018 03:10 PM |
STI Brembo HELP ~ | Trap63 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 08-02-2013 06:59 PM |
