Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-27-2021, 07:30 AM | #1 |
Drives: Blue Hikari Brz
Has anyone ever heard this sound on their ft86 (Strange Engine Noise *Video)
It was 40deg today in my city and I was doing a few practice launches on an empty road and on the 3rd pull I started hearing a strange rattle coming from the engine (driver side), it only seems to appear between 3000-4000 RPM. Could it be from the heat? Oil pressure? HeatShield Rattle? Valve?
It makes the same noise if it's idle or driving. Not sure if I should tow my car to shop or continue driving? 2016 BRZ with 40,000km (no previous issues and no engine mods or tune) (Video Attached) https://drive.google.com/file/d/1_EU...ew?usp=sharing |
06-27-2021, 08:30 AM | #2 |
ProCrastinationConsultant
all that exterior work, and zero mechanical mods at all? not even an exhaust/headers?
have you checked your oil level, and exhaust connections yet?
06-27-2021, 08:42 PM | #3 |
Drives: car
I'd take a screwdriver and probe/listen for it.
Could be a worn throw out bearing. |
06-28-2021, 01:20 AM | #4 |
Drives: 2013 FRS
Push the clutch in slightly in neutral sitting still, does the sound go away?
11-16-2021, 07:45 PM | #5 |
Drives: 2015 midnight blue limited edition.
Did you ever figure this out ?
Sent from my Pixel 3 using Tapatalk |
11-24-2021, 02:45 AM | #6 |
Drives: 2016 Oceanic, "base" model
Does it happen at 3400rpm? If so, I believe it's the VVTi actuator not working. I have had a "death rattle" sound on my 2016 since 30k miles. I've been able to reduce how often it happens (I believe) by using 0W-30 oil but I've read you can actually fix it by replacing the "VVTi filter", or something like that. Just been too lazy to properly deal with it...
Similar Threads | ||||
Strange sound from Engine/Exhaust | malkduds | Issues | Warranty | Recalls / TSB | 1 | 11-17-2020 08:26 AM |
Strange Noise When Parked and Off Video | Alott53 | Issues | Warranty | Recalls / TSB | 11 | 07-27-2015 11:08 PM |
Rattling Engine Noise (Video with sound) | mystic | Southern California | 21 | 12-28-2013 04:11 AM |
Strange engine noise during startup (Video inside) | StOpNG0x | Issues | Warranty | Recalls / TSB | 2 | 01-29-2013 07:24 AM |
Strange Sound From Noise Tube | bkneal | Issues | Warranty | Recalls / TSB | 6 | 11-01-2012 04:17 PM |
