Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
06-01-2021, 09:36 PM | #1 |
Drives: LS swapped FR-S
18x9 +40 with 265s stock suspension
Hey guys,
Long story short - LS Swapped FR-S, 8" wheels are too small. I have a tune scheduled for 6/7 so I found some wheels that are 18x9 +40 offset running 265/35/18s. The car is on stock suspension (for now), I am wondering if there is going to be any rubbing or clearance issues? I did run through the forum, but all of this is coming down the wire and I'd like to know before I run out of time lol. Thanks guys! |
06-01-2021, 09:57 PM | #2 |
Drives: Crapcan
Tires are probably going to rub the springs in the front.
06-03-2021, 12:43 PM | #3 |
Agree. I would get some camber plates to add to the stock shocks and get a 3-5mm spacer with extended studs.
2013 Series 10 FRS #553
06-03-2021, 04:19 PM | #4 |
Site Moderator
Drives: ichi 86 Project
Don't think 3-5mm spacer won't do it. Need at least 7mm
06-03-2021, 04:43 PM | #5 |
Barred
Drives: My18 wrxsti My19 brzts
Camber plates change nothing as the strut and tire move together. The rim itself will be 7/16 11.1mm closer to the strut and the tire will poke more inside and outside.
Wait until my Flex capacitor hits 88
06-04-2021, 11:51 AM | #6 | |
Drives: 2013 BRZ Sport-Tech
I fit 255 RS4's on the front with the stock struts, camber plates, and camber bolts. I don't recall what my wheel offset was. I ran a 3mm spacer up front but none in the back. Not sure what tires OP plans to run but if they run as wide as RS4's I expect they'll poke past the fender by a little at least. |
06-04-2021, 12:41 PM | #7 |
Purist
Drives: 2013 FRS - Hot Lava
17X9 +42 fit on stock struts. I dont see why an 18" wheel would make a difference. It would be very tight and you couldnt run any camber whatsoever.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
06-04-2021, 12:43 PM | #8 |
Drives: Crapcan
17x9 +38 with 245’s had only about 6mm of clearance between the inside of the tire and spring on my car. Would rub the springs until they came up to temp/pressure.
Tags |
18x9, 265, wheels |
Similar Threads | ||||
Stock suspension with 18x9 wheels | fujin86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-13-2019 04:12 PM |
Will konig deckagram 18x9.5 +35mm off fit stock suspension? | Bread1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 03-23-2018 10:41 AM |
Kiwami 18x9.5 all round. Stock Suspension | sNake89 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 02-16-2016 06:30 AM |
18x8 front and 18x9.5 on stock suspension | Jayela | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 10-07-2015 11:02 PM |
18x9.5 et 40- temporary on stock suspension? spacers? | mkivalex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-25-2014 08:36 AM |
