Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-12-2021, 05:37 PM | #1 |
Seņor Member
Drives: '17 BRZ PP
Misalignment after hitting pothole?
I was leaving a BK drive-through, and the street parallel to it is next to a building under construction. It was raining, and as I was leaving I hit a pot hole, HARD. It was full of water so it was impossible to see. The front and rear right tires hit it. What is the chance the camber or toe settings got wrecked?
Car drives okay, there are no weird noises, but I haven't had much time to drive it except while getting home after the impact. Coils are HKS SP 8k/8k, midway dampening settings and 1 in drop. |
05-12-2021, 05:43 PM | #2 |
Drives: Toyota 86
High, alignment slips more frequently than you may think especially using camber bolts and rear stock toe arms.
05-12-2021, 06:11 PM | #3 |
ProCrastinationConsultant
potholes happen
05-13-2021, 12:25 AM | #4 | |
Seņor Member
Drives: '17 BRZ PP
more than anything, I'm concerned this could lead to a busted strut tower in the future. there's a lad in the twins subreddit recently that had a destroyed strut tower and the concensus was it's pretty much impossible to properly fix. hope Im wrong. |
05-13-2021, 01:40 AM | #5 |
Wheels for Brains
I've hit stuff way harder and my strut towers are just fine. I wouldn't worry about the towers
Easiest way to tell if you need a new alignment is if the car handles differently or the steering isn't centered anymore. Check the wheel for bends. If the wheels are bent, probably alignment will need some help as well. That isn't to say that the alignment got jiggled anyway (regardless of whether or not the wheels are bent). Not anything out of the ordinary as far as potholes and impacts go |
05-13-2021, 03:34 PM | #6 | |
Seņor Member
Drives: '17 BRZ PP
But other than that it seems to be driving okay still. Wheels are not bent, but they are the durable and heavy OEM PP wheels. I wonder if my TC105xs or some RPF1s would have survived that. |
05-13-2021, 03:37 PM | #7 | |
Wheels for Brains
05-13-2021, 05:30 PM | #8 | |
Seņor Member
Drives: '17 BRZ PP
https://www.reddit.com/r/ft86/commen...ng_the_engine/ |
05-13-2021, 07:23 PM | #9 | |
05-13-2021, 08:36 PM | #10 | |
The towers are not made out of sugar and can take a beating. That is why you have suspension and not solid bolt on axles. They take the bulk of the hit. Yes, you will get bounced around a bit and can bend wheels, snap bearings and all sort of weird and wonderful things but damaging a tower by hitting a pothole would be spectacular. The dude on Reddit is either not telling the whole story or it happened before he got the car. My guess in that case would be a very poor installation job on the coilover not damage from a bump. A bump causing that would have shattered pain and created stress marks. There is no sign of any upward force at all.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Plumbus (05-14-2021), soundman98 (05-13-2021) |
Tags |
alignment, coilovers, construction, fuck, pot hole |
Similar Threads | ||||
Deleted | turboencabulatr | Issues | Warranty | Recalls / TSB | 11 | 05-11-2020 02:18 PM |
Front fender and rocker misalignment | midnitz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 07-26-2019 07:38 AM |
GrimmSpeed Intake Misalignment? | ryoma | Engine, Exhaust, Transmission | 4 | 04-20-2015 11:15 AM |
hit a pothole doing 70mph | dori. | BRZ First-Gen (2012+) -- General Topics | 22 | 03-22-2013 10:46 PM |
Hit pothole blew tire.... now have odd sound | clayrush | Issues | Warranty | Recalls / TSB | 15 | 08-23-2012 11:57 PM |
