Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-10-2021, 08:37 PM | #1 |
Drives: 2023 GR86
AOS/Catch Can Needed for Supercharger Support Mod?
I know this is one of the most debated questions in the 86 community.
I ask this question because CSG Mike brings up the point of an AOS/Catch Can not being necessary due to the differing design of FA20 vs the traditional boxer motors boxer-heads like to focus on (mainly the EJ). So what do the other 86 owners think? I'd like to hear from everyone who has a strong opinion! |
04-10-2021, 09:31 PM | #2 | |
Sent from my ONEPLUS A5010 using Tapatalk |
04-10-2021, 10:40 PM | #3 |
Drives: 2023 GR86
04-10-2021, 10:41 PM | #4 |
04-10-2021, 10:42 PM | #5 |
Rust bucket enthusiast
I think it catches vapor. Mine caught some if I was hammering on it a lot. Not certain how much "catching" it helps though. I think it's nice to be able see monitor how much you're getting and not recirculate it
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
The Following User Says Thank You to DarkPira7e For This Useful Post: | Jasper (04-10-2021) |
04-10-2021, 10:58 PM | #6 | |
The Following 2 Users Say Thank You to Ashikabi For This Useful Post: | DarkPira7e (04-10-2021), Jasper (04-11-2021) |
04-10-2021, 11:31 PM | #7 | |
04-11-2021, 10:04 AM | #8 |
Drives: GT 86
I would Defiantly put a catch can in as it cost us a new motor when tracking the car due to oil and the result was 4 bent rods !
04-11-2021, 10:42 AM | #9 |
Drives: Crapcan
How the heck did that happen? Was it pushing enough oil to hydraulic lock the engine?
04-11-2021, 10:49 AM | #10 |
LMGTFY
Drives: 13 FRS, 91 Miata
As I said in the other thread.
A catch can is used to monitor engine health. And as Mike said, you probably don't need one unless pushing the engine hard. If its catching alot of fluid something is wrong with the engine. Do you feel the engine is or might in the future have blowby/pcv problems, get one. Get one if you are going to be pushing the engine hard alot. (Track Use) Or get one just because you want the peace of mind. Otherwise on a daily, don't bother. |
The Following 2 Users Say Thank You to x808drifter For This Useful Post: | bfrank1972 (04-12-2021), Jasper (04-11-2021) |
04-12-2021, 07:23 AM | #11 | |
Drives: GT 86
The cornering G forces were very high and yes pushing hard but we did manage to drive/nurse it home from the track. |
The Following User Says Thank You to sam69 For This Useful Post: | Jasper (04-12-2021) |
04-12-2021, 10:37 AM | #12 | |
Drives: 2013 FR-S Argento
This. Depends on your setup and driving. If you're running super high boost, if your motor is tired/has a lot of blow-boy, if you track hard and frequently, it's a good safety mechanism and good indicator of how your motor is holding compression. If your motor is healthy, and you're running something like an 8 or 9 psi unit (especially a centrifugal unit), you probably don't need it unless you suspect your motor is tired (high mileage, uses oil). I have catch can on both PCV and CCV, PCV doesn't collect hardly anything, and CCV absolutely nothing. I'm running a Vortech unit that peaks around 11psi. Some motors naturally use more oil than others, so if you want to be safe, just spend a couple hundred bucks and get one for the PCV side. |
04-12-2021, 10:45 AM | #13 |
Drives: Crapcan
Me thinks there was another extenuating circumstance. I would 100% run an AOS boosted on track, but I can't imagine it pushing that much fluid to bend a rod let alone multiple rods.
04-12-2021, 01:46 PM | #14 | |
The Following User Says Thank You to Ashikabi For This Useful Post: | Jasper (04-12-2021) |
Tags |
aos, catch can, forced induction, supercharger, supporting mods |
Similar Threads | ||||
Radium Dual Catch Can with Jackson Racing Supercharger | pabisz23 | Forced Induction | 3 | 07-10-2020 09:25 AM |
Supercharger and catch cans | sqd | Forced Induction | 3 | 04-15-2019 09:18 AM |
Catch can for supercharger by Jon Bond Performance | sroby | Engine, Exhaust, Bolt-Ons | 0 | 07-11-2018 10:01 PM |
BRZ Supercharger Motorhead info needed | Saifalkhalifa1 | FR-S / BRZ vs.... | 1 | 08-07-2016 02:41 PM |
Anybody catch this? Stout Racing SCCA Scion FR-S w/ TRD Supercharger at SEMA | BK025 | Scion FR-S / Toyota 86 GT86 General Forum | 68 | 01-30-2013 03:29 AM |
