Old 03-28-2021, 02:01 PM   #1
Kaleb765
Kaleb765's Avatar
Drives: 2015 Scion FR-S Raven Black
Valenti 4th Brake Light Issue
So I was rewiring the light to separate the V and the brake triangle, I did this successfully before on my car. So I was helping a buddy with his and made a dumb mistake, I attached the left black wire to the screw to the left of the node and we then tested the light and that’s when I discovered the incorrect placement. I since corrected the mistake but we are still not getting any power to the V or triangle...did I fry the board from sending power incorrectly? I circled the area in question in the picture
Kaleb765 is offline   Reply With Quote
Old 03-28-2021, 02:07 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
have you checked fuses?
Kaleb765 (03-28-2021)
Old 03-28-2021, 02:19 PM   #3
Kaleb765
Kaleb765's Avatar
I have not! Do you know which ones I should check? Thank you for the quick reply!!
Old 03-29-2021, 08:07 AM   #4
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Are you receiving 12v, but the light doesn't turn on? Or do you not have 12v power being supplied at all? A multimeter is your best friend here, both for checking for power and checking fuses.
If you have no 12v, then as @soundman98 said check fuses. I would also suggest bench testing the light off the car first with a 12v power source/inverter.
If there is 12v, then there's likely a problem with the board or connections.
sharpsicle is offline   Reply With Quote
Valenti fourth brake light install issue spike021 Cosmetic Modification (Interior/Exterior/Lighting) 17 03-10-2022 07:26 PM
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
Valenti 4th brake light vs Valenti Style brake light? JGalp Electronics | Audio | NAV | Infotainment 9 03-24-2016 05:48 PM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 06:51 PM
