BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
03-27-2021, 10:20 PM | #1 |
Drives: 2020 Subaru BRZ Sport-tech
Reco for brake pads for track use?
Hi all,
I currently have Brembos with stock brake pads, but i want to get some pads that are better for the track. Any suggestions? I would prefer to have something a bit more durable than performance, if it matters (I'm still a beginner so not trying to set records or anything). Thanks. |
03-31-2021, 05:43 PM | #2 | |
Drives: 2019 BMW ///M4
Probably like HAWK HT-10, HAWK DTC-60, Ferodo, Carbotech, etc. Something that isn't a street pad or a "high performance street pad". Swap back to stock pads after you're done. I don't actually know what fits in OEM Brembo calipers, but I am sure Brembo probably carries a more aggressive pad. Don't bother with any drilled or slotted rotors, blanks are best. Also run dedicated track tires like Cup2s, AD08R, R888R, RS4, something a long that line (if you can afford). Recommend upgraded brake fluid as well.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
03-31-2021, 06:17 PM | #3 |
Upgrade brake fluid first. I would not worry about pads until they tell you they are not up to your driving ability. More durable than performance are stock pads.
04-01-2021, 07:21 AM | #4 |
Drives: '23 BRZ
I've never tried the stock PP Brembo pads at the track, they may well be OK for a few laps. But yeah, ultimately you're likely to need more track-appropriate pads and better to go in prepared. There's no one answer here as different people, even running the same lap times in the same car, can have very different requirements for feel and place very different demands on the brakes.
I've run Carbotech XP8 and XP10 on other cars and I thought they were pretty good and lasted well enough (~10-12 track days). Currently running CSG C2 which have better bite/higher friction feel which I like. $$$ tho... They have other options as well. You might contact the supplier with your intended usage and desires/expectations to get a recommendation. As mentioned above, fluid is important too. I've never had any problems just running off-the-shelf parts store DOT4, no need to source more "exotic" brake fluid IMO. |
04-01-2021, 11:23 AM | #5 | |
Brake fluid like this? Very popular on the M cars. https://www.amazon.com/Castrol-SRF-R.../dp/B002TM4GBQ
N1rve
04-01-2021, 11:34 AM | #6 | |
Drives: '23 BRZ
Some people just LOVE to spend money on "special" things, whether they need it or not... |
04-01-2021, 02:10 PM | #7 | |
SRF: Wet boiling point is 270deg. C Dry boiling point is 310deg. C Motul: Dry boiling point 594F(312C) Wet boiling point 399F(204C). But like SRF $70L vs RBF 600 $32L.... almost 2X the price!
N1rve
04-01-2021, 02:40 PM | #8 |
Drives: '23 BRZ
I've never had a need for anything beyond this, even in a 550hp FD...
The Following User Says Thank You to ZDan For This Useful Post: | Pat (04-06-2021) |
04-01-2021, 03:16 PM | #9 |
Barred
Drives: My18 wrxsti My19 brzts
Running this for years. $9.85. Never Failed. The only thing I do is bleed the fluid that has been heated in the calipers out before every track day. This keeps the brake fluid in the system fresh as after a few bleeds it`s all replaced.
Wait until my Flex capacitor hits 88
04-01-2021, 03:42 PM | #10 | |
PM me to order. |
04-01-2021, 04:30 PM | #11 | |
I'd recommend doing some research on the forums (we have a great subforum with tons of info) before just going along and buying one that someone wants you to order.
Instagram: @spike.brz
04-06-2021, 10:20 AM | #12 | |
Drives: 2013 BRZ Sport-Tech
So I stuck with Typ200 (too bad you can't get super blue anymore) |
04-06-2021, 12:06 PM | #13 |
Rust bucket enthusiast
I still have an unopened can of the ATE superblue in my garage. I will keep it forever
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
04-06-2021, 12:51 PM | #14 | |
https://www.amazon.com/dp/B07KY29SY6...ing=UTF8&psc=1
N1rve
Similar Threads | ||||
Brake Pads for track use | ThaDonJsuan | BRZ First-Gen (2012+) -- General Topics | 8 | 11-15-2020 04:35 PM |
Brake Pads for Track/Street Use | bumperhumper | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 06-17-2020 03:54 PM |
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo | tampaSi | Brakes, Suspension, Chassis | 4 | 05-27-2017 02:31 PM |
How to restore OEM brake pads after a track day? | torqdork | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 09-24-2013 12:45 PM |
Brake pads for track days | why | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-26-2013 06:42 PM |
