Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-21-2021, 11:29 AM | #1 |
Drives: 2017 BRZ w/PP
are these shift level retainer bushings?
i just did my clutch last night and cleaning up i found these under the cardboard i layed down. Im pretty sure they fell out where the pins went
03-21-2021, 01:06 PM | #2 |
Drives: 2018 BRZ
Yep, those are the front shifter carrier bushings. These go around a pin which is locked in placed by a rotating tab, if that rings any bells.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | Breadman (03-21-2021) |
03-21-2021, 01:28 PM | #3 | |
damn it i must have accidentally pushed the inside ones out when putting those pins back in. i need to change the diff so i guess ill drop the drive shaft and reach up there |
03-21-2021, 01:33 PM | #4 |
Drives: 2018 BRZ
You can access them without removing anything, but it's pretty tight and blind. I replaced mine with stiffer ones mainly by feel.
03-21-2021, 02:01 PM | #5 | |
yeah my plan is to disconnect the trans mount so i sag it down a bit then disconnect the shift linkage so i can push it to the side and then use a pick to pop the hooks off. then i need to feel which ones i pushed out by mistake |
03-21-2021, 04:38 PM | #6 |
chicken tonight
How I support the engine with a tie-down strap when removing the transmission
shameless *cough* plug
Similar Threads | ||||
Cusco shift lever retainer bushing | radroach | Engine, Exhaust, Transmission | 5 | 04-29-2017 09:40 PM |
FS: Whiteline bushings KDT926 (Positive shift kit) & KDT922 (Positive traction kit) | Tim_Asphalt_FRS | Transmission and Driveline | 3 | 09-26-2014 11:41 AM |
WTB: OEM Manual Shift Boot Plastic Retainer | soulstice | Interior Parts (Incl. Lighting) | 0 | 06-20-2013 05:46 PM |
WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 5 | 01-16-2013 05:15 PM |
***MEGA THREAD*** Shifter Bushings | Shift Knobs | Clutches | Flywheels | Dif Covers | FT-86 SpeedFactory | Transmission and Driveline | 1 | 07-26-2012 08:46 AM |
