Old 03-01-2021, 09:54 PM   #1
doug1234
doug1234's Avatar
Drives: 2017 BRZ w/pp
949 lug nut advice needed
Just purchased a set of 949 Racing Lug Nuts. Been researching if the use of anti-seize is need. Like always many options.
If I use anti-seize. What type? What is the new torque values? How should the anti-seize be applied?
If I don't use anti-seize. Has anybody had problems with the lugs seizing to the studs?
APR studs
APEX Arc8 wheel
Maxxis VR-1
HPDE about once a month starting in March, Maryland Area.
Sent from my Pixel 2 XL using Tapatalk
doug1234 is offline   Reply With Quote
Old 03-02-2021, 12:39 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
One shouldn't use anti-seize on lugnuts. It alters torque values thus increases chances for insecure mount or chance to strip threads if overtorquing to compensate reduced friction with extra torque. Torque values are rated for dry threads only.
Just clean with wire brush/rug threads before torquing lugnuts back on, do first turns with hand to prevent cross-threading, and also don't use powertools for final torquing. Then even alu lugnuts should last reasonably. For piece of mind i'd still prefer steel lugnuts on tracked car whose wheels get changed 10+x more often then that of DD only car.
Alignment Advice Needed Zero3210 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 08-18-2020 01:05 PM
Some advice needed please pevsfreedom Engine, Exhaust, Transmission 0 10-20-2019 08:34 PM
Advice Needed -- DD for $1K carczar87 Other Vehicles & General Automotive Discussions 29 10-05-2017 07:10 PM
What to do.. Advice needed fuddbutter AUSTRALIA 44 01-29-2013 07:02 AM
