Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-13-2020, 12:02 PM | #1 |
Drives: 13 FR-S
Questions About Built Blocks/Supercharging
Hey, owner of an early build (affected by valve spring recall) 71K mile 2013 FR-S here. Sunday, my engine started knocking (bottom end) while cruising on the thruway, and partially seized due to heat as I put the clutch in and pulled over.
Backstory: First things first, I had it tuned by a friend who has done plenty of other applications, they basically put in a little timing and messed with the air/fuel targets to smooth out the torque dip and take advantage of the intake/exhaust I had put on a few months back. This was about three weeks ago. I use the car mainly for autocross and sometimes for track days, mostly Toronto Motorsports Park when the border is open. Once or twice a year for the track, multiple weekends for autocross. I ran the car at autocross with the tune for 8 runs and had no issues, this was on the 4th. I've done regular oil changes and owned the car since 15K miles four years ago. I daily it. The oil was full when it started knocking, no engine lights illuminated, no oil light on, nothing. Questions: This sounds like an oil starvation issue to me, seeing as I wasn't putting the car through anything I normally wouldn't on a weekend or track day. My local Toyota dealership is currently tearing the car down, but it looks like I'm looking at replacement. They stated it idles (poorly) and needed throttle at first to keep running, and there's a bottom end noise. My long term goal with this car was to supercharge, but rather than spending $16K on a new stock assembly, I'd like to go built. I'm seeing a few options out there so in regards to that: Does compression ratio matter on a stock/street tune? I won't be supercharging it just yet. The car normally runs at 12.5:1 obviously, if I throw in a 10:1 ratio block, will the car perform poorly without forced induction? I can turn a wrench pretty well and know how a car works, but more technical stuff like tuning escapes me. I know what compression does, I've just never changed compression on a vehicle before, so unknown territory for me. I know I'll need more than just the short block, do the stock heads and front cover suffice for built applications or should I source/upgrade that stuff as well? I'll have the dealership source any lines or miscellaneous parts that can't be reused from the old engine, so I'm not on an endless hunt. I'll know the full story tomorrow, looking for feedback so I can start ordering the right parts and get the car back on the road sooner rather than later. TIA! |
The Following User Says Thank You to SirEspo For This Useful Post: | RFB (10-13-2020) |
10-13-2020, 12:22 PM | #2 |
Honestly I'd just throw in a used engine and supercharge that one. If all you want is the same power everyone else is making then it should hold up ok. If you do want it built, reduced compression allows you to run more boost/timing, therefore more power. You will have less power in the mean time but I couldn't tell you how much.
Sent from my ONEPLUS A5010 using Tapatalk |
The Following 2 Users Say Thank You to Ashikabi For This Useful Post: | alphasaur (10-13-2020), DarkPira7e (10-13-2020) |
10-13-2020, 01:35 PM | #3 | |
Noob
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
Sent from my Pixel 4 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599 -1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black |
10-13-2020, 01:43 PM | #4 | |
Drives: FRS
Again, INMHO a supercharger is limited in sufficient boost. Turbos can give higher boost and would be more appropriate. Jackson superchargers give more power and torque quicker with stock compression, but can hurt non strengthened innards. In the last 9 years have seen several stock blocks blown from excessive track use, as well as the supercharged or turbo'd unbuilt motors (and over boosted BUILT blocks, one blown several times !). Has anyone built a block with stock compression ratio or used custom pistons at 11.5 to 1 for HP of more than 275 to 300 (split the difference so to speak) ? - Something I have yet to see on our tracks. |
The Following User Says Thank You to RFB For This Useful Post: | SirEspo (10-13-2020) |
10-13-2020, 01:45 PM | #5 | |
Noob
10-13-2020, 02:43 PM | #6 |
Drives: FRS
10-13-2020, 03:17 PM | #7 |
friendly
Drives: 17' 86
Do you run an oil cooler?
If not, do you monitor oil temperatures while tracking? Based on everything I have read I would be cautious building an engine, at that point I think an engine swap becomes a viable plan and you will end up with a better platform. Our engine IMO is not bad, there's just better out there if you're going to invest the money in a build.
Seek comfort in discomfort.
10-13-2020, 03:56 PM | #8 | |
10-13-2020, 05:06 PM | #9 | |||
Drives: 13 FR-S
Side note, I'm seeing lots of short blocks, and to make this as easy as possible, it looks like I basically need the whole long block. The accessories off my car can all be used - A/C, heater elements, etc. Any suggestions on companies retailing fully built units like this? |
10-13-2020, 05:34 PM | #10 |
Drives: '13 Whiteout
I went with an IAG short block stage 1 which is good for 550 hp. I’m staying NA for now but have much more confidence in the motor when I’m on track. Not sure if I’ll go FI but good to know I’m set up for it.
The Following User Says Thank You to TommyW For This Useful Post: | alphasaur (10-13-2020) |
10-13-2020, 07:23 PM | #11 | |
friendly
Drives: 17' 86
The consensus seems to be that an oil cooler is needed for track driving even while stock. If you drive enthusiastically on back roads you can easily get oil temps into the 220+ range while stock. What weight oil did you use?
10-13-2020, 07:31 PM | #12 | |
The Following User Says Thank You to Ashikabi For This Useful Post: | alphasaur (10-13-2020) |
10-13-2020, 07:59 PM | #13 | ||
Drives: 13 FR-S
I used 0W-20 as recommended. Always full synthetic, usually Pennzoil or Mobil1. |
The Following User Says Thank You to SirEspo For This Useful Post: | alphasaur (10-13-2020) |
10-13-2020, 08:04 PM | #14 | |
Similar Threads | ||||
FBM stage 1 built block questions | Matey | Engine, Exhaust, Transmission | 5 | 03-24-2017 07:39 AM |
Questions and Discussion on Vortech Supercharging Systems | Brian@Vortech | Forced Induction | 1462 | 01-27-2017 02:05 PM |
Supercharging an automatic (AT) FR-S | dp1 | Forced Induction | 37 | 06-11-2014 05:18 PM |
Supercharging the GT86 | Billy2224 | Engine, Exhaust, Transmission | 13 | 06-05-2012 03:58 PM |
Turbo/Supercharging Your FRS | BoostJunkie | Engine, Exhaust, Transmission | 123 | 05-18-2012 06:26 PM |
