Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
08-12-2020, 03:37 PM | #1 |
Drives: 2013 FRS
720 Form GTF1 Wheels, stock lug nuts or tuner style?
Looking at buying 720 Form GTF1 17x8 et35 wheels.
1010tire.com cant tell me if the stock lugnuts will work. Anyone with a set that can chime in? |
08-12-2020, 05:07 PM | #2 |
Sarcastic SOB
I had GTF1 and eventually switched to GTF2.
They do require tuner nuts.
08-14-2020, 08:16 PM | #3 |
Drives: 2013 FRS
Thanks.
08-15-2020, 05:40 AM | #4 |
Drives: 2014 GT86
as "tuner nuts" usually are referred 60deg conical seat lugnuts. Stock lugnuts of twins also are 60dg conical seat ones. I don't know for sure what seat your wheels have though. Then again, most aftermarket wheels have such lugnut seat shape. In most cases one may need aftermarket lugnuts (eg. longer ones, or open-ended ones), if one has installed extended length wheel studs to enable usage of thicker slip-on wheel spacers.
The Following User Says Thank You to churchx For This Useful Post: | why? (08-15-2020) |
08-15-2020, 07:56 AM | #5 |
TRACKBREAD
Stock lugs nuts are tuner style, they’ll work.
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | why? (08-15-2020) |
08-15-2020, 10:28 AM | #6 |
Only happy when it rains.
Drives: series.blue
Almost all aftermarket wheels the stock lug nuts work. Every so often an aftermarket wheel has smaller openings for the lugs, which is annoying. I ran in to this on some used Moteki wheels I bought.
Similar Threads | ||||
720 Form GTF1 BBK fitment?? | Jordanwolf | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-31-2018 08:51 PM |
f/s 720 Form GTF1 17x8 +35 w/PSS 215-45 | wbradley | Canada Classifieds | 22 | 05-14-2018 06:34 PM |
720 Form GTF1 Stock Height - Wheels are on!! | Jordanwolf | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 63 | 04-23-2018 05:50 PM |
72o form GTF1 quality | dostoyevsky | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-08-2018 12:08 PM |
