Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
07-05-2020, 12:42 PM | #1 |
Drives: 2014 FRS
Looking to change my trans and diff fluid soon, what your guy's go-to and why?
Looking to get my trans and diff fluid changed soon, what's your guy's pick and why? Narrowed it down to Redline, RP, and Motul............ or is it better to stick to OEM???
07-05-2020, 12:47 PM | #2 |
Drives: Scion FR-S 10 Series
I use Motul as it seem to deal with heat better, which is nice during the hot summer and track days.
The Following User Says Thank You to Jdmjunkie For This Useful Post: | why? (07-30-2020) |
07-05-2020, 12:51 PM | #3 |
Rust bucket enthusiast
Motul, because it's been effective and seems to have completely removed my cold temperature shifting issue (below 0 degrees f) and also might have helped fix my 4th gear grind every time I'd shift into it at high RPM.
This could simply be due to the original fluid in the car being trash. I changed it a few months after I bought the car with 22,000 miles on it. I also really like that the cap has a built in funnel |
07-05-2020, 03:35 PM | #4 |
Drives: '13 Subaru BRZ Crystal Black Silica
Redline MT-90. Rated for GL-1, GL-3, GL4. The product description felt more appealing to me compared to other fluids I've used. Our aisin transmissions use GL-3. but GL-3 is obsolete so I use MT-90. Call me paranoid, but I personally do not like the GL4/5 products.
https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil
IG: setgo.moto
The Following User Says Thank You to Setgo For This Useful Post: | JesseG (07-16-2020) |
07-05-2020, 03:51 PM | #5 |
Panda Trueno
Drives: No twin now.
Got rid of stock for motul. Better shifting, and I've been happy with it.
07-05-2020, 07:00 PM | #6 |
Drives: 2020 Subaru BRZ TS
The general consensus seems to be that Motul is the most popular option. I'll go with that one too come fluid change time.
07-05-2020, 11:31 PM | #7 |
[insert cool phrase here]
Drives: BRZ Premium
I have Redline in mine. Zero issues.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
07-06-2020, 01:15 AM | #8 |
Forgot to mention Amsoil. Excellent product also. And more readily available here in Canada.
07-06-2020, 01:10 PM | #9 |
Drives: Crapcan
Another one for Redline.
07-07-2020, 01:27 AM | #10 |
6/22/12-2/6/24
I've used Motul Motylgear (was better than stock), currently have Motul 300 (I think its about the same .. maybe better than the Motylgear).
Overall I'm happy with it. Occasionally 1st and 5th aren't too happy. Another oil I've been debating is: https://products.liqui-moly.com/oils...ct-media-modal I just tried LiquiMoly's engine oil additive CeraTec which has been pretty amazing. I reached out to LiquiMoly and they recommended to use MoS2 isntead of Ceratec and their High Performance Gear Oil with the MoS2. So I'm debating that now. This is LiquiMoly's email: "thank you for sending us your request regarding Ceratec's use in manual transmissions. Your manual transmission on your Scion is better of using our anti-friction additive named MoS2 Anti-Friction for Gears. This additive is specifically designed for use in gearboxes and differentials and will be the best choice for your 6 speed transmission. Lower internal friction will add protection to gears, bearings and synchros. Also make sure to use a high quality gear oil in the transmission, like our High Performance Gear Oil GL4+ 75W90. Please let me know if you have any questions. Stefan Braun Application Specialist"
The Following User Says Thank You to Bonburner For This Useful Post: | JesseG (07-16-2020) |
07-07-2020, 05:03 PM | #11 |
Drives: Nevermorange FRS
Pennzoil synchromesh. 85k street miles and almost 2 full race seasons and not a single crunch or grind.
None of that fully synthetic stuff for me in the trans. Synchros like a little friction - their very job function specifically relies on it.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | gravitylover (07-21-2020) |
07-07-2020, 10:23 PM | #12 |
The Dictater
Drives: '13 Red Scion FRS
+1 for Amsoil in case you didn't eliminate it outright.
My thoughts: https://www.ft86club.com/forums/showthread.php?t=127620 |
07-14-2020, 01:07 PM | #13 |
Only users lose drugs.
Drives: All the time
So far I've run the OEM fill, Toyota's recommended refill LV 75W, Amsoil, and Motul...all GL4 or lower (I think the Toyota LV 75W is GL3...). Of the 4, Amsoil performed noticeably worse when cold. Motul seems to edge out the OEM fill and Toyota LV 75W, but not by a whole lot. I might try Pennzoil Syncromesh next time.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
07-15-2020, 03:43 AM | #14 |
Drives: 2017 subaru brz
I am thoroughly confused by which oil to use after reading almost every thread on this forum lol. I've had no issues with my oem fluids so far @ 30k miles and would like to stick with OEM fluids.
However, everyone on the forums states to not use GL5 rated fluid in the manual transmission, however, it seems like the only current oem option from Subaru is GL5 specification (SOA427V1700). So does this mean it is not safe to use oem fluid in our transmissions? Also, would this part number be just fine to use in the differential? (not sure if we need something specific for LSD). Thanks. This is the OEM part I'm referring to: https://ftspeed.com/part/soa427v1700...-1qt-universal |
Tags |
differential, fluids, maintenance, oil, transmission fluid |
Similar Threads | ||||
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG | jfg5067 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 01-18-2016 09:24 AM |
Trans and Diff fluid change feedback | Freedom | AFRICA | 0 | 08-07-2015 11:52 AM |
Manual Trans./Diff. Fluid Change.?. | westmansweed | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-15-2015 08:02 AM |
Replacing Trans & Diff Fluid, Hot vs Cold | BRZNutt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 12-22-2013 09:04 PM |
Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 03:11 PM |
