Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
06-26-2020, 02:36 AM | #1 |
Drives: 2014 White FRS
Yellow/green stain after badge removal with wd40 goo gone
Hello, there's a weird yellow stain after I debadged the front emblem and used wd40 and goo gone for residue?
I have no idea how it happened. I was using a yellow microfiber cloth, wd40 and, goo gone automotive spray. After several scrubs I notice the area I'm scrubbing is turning yellow I immediately used nail polish remover in hopes of removing any chemical residue. It took away some stain but not all. The stain is all over the front emblem area but not where the adhesive was. If that makes sense. It's also in the area where I was scrubbing (area around emblem). To add, after using wd40, I notice the tape residue is turning green. But wd40 won't normally cause stain? What caused this and how should I fix it? Thank you |
06-27-2020, 02:28 PM | #2 |
Do you have a pic? I’m thinking you may have stained the clear coat. If that’s the case, put some rubbing compound on a mf towel and rub the affected areas. Don’t use any more chemicals.
The Following 2 Users Say Thank You to MyRx For This Useful Post: | DarkPira7e (06-27-2020), golemslord (06-28-2020) |
06-27-2020, 02:31 PM | #3 |
Rust bucket enthusiast
Try a buffing complaint or wetsanding.
The Following User Says Thank You to DarkPira7e For This Useful Post: | golemslord (06-28-2020) |
06-27-2020, 02:38 PM | #4 |
Drives: 17 Asphalt 86
Small chance an iron/fallout remover may get it out.
I'd just use a polish with a MF, and if that doesn't work a compound will get it out. Follow up with a polish to bring back depth and clarity. |
The Following User Says Thank You to RToyo86 For This Useful Post: | golemslord (06-28-2020) |
06-27-2020, 04:33 PM | #5 | |
Wetsanding wouldn’t be for a beginner. Much more aggressive than using a medium/heavy cut compound and a mf towel. What the op decribes, the wd40 may have bled the yellow mf towel onto the clearcoat. Start with light/medium compound and mf towel.
No chance iron decon will remove a stain. That’s a chemical decon, he needs a mechanical action - compound and a mf towel.
The Following 2 Users Say Thank You to MyRx For This Useful Post: | golemslord (06-28-2020), soundman98 (06-27-2020) |
06-28-2020, 05:52 AM | #6 | |
06-28-2020, 05:56 AM | #7 |
Drives: Subaru BRZ
Just had a thought, if you can't make it go away then I suggest that you stick a badge over it.. the brilliance of this suggestion is that the bonnet has a small indentation and some carefully crafted lines that will take your eye to the badge.. almost as if it was designed to have badge there....
The Following User Says Thank You to JD001 For This Useful Post: | soundman98 (06-28-2020) |
06-28-2020, 05:47 PM | #8 | |
Do you have a non-yellow mf towel? Or a washed clean one? Avoid using a brand new, unwashed yellow mf. Any slight cleaner on a colored mf can bleed out onto a surface.
The Following User Says Thank You to MyRx For This Useful Post: | golemslord (07-01-2020) |
07-01-2020, 01:26 AM | #9 | |
The Following User Says Thank You to golemslord For This Useful Post: | JD001 (07-01-2020) |
Similar Threads | ||||
Help. Got a yellow stain | icecord | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 26 | 10-05-2016 12:53 PM |
Oil Stain Removal | FRSNewb | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 06-07-2015 10:07 AM |
Green or Yellow Wheels on Ultramarine | bfsnail | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 07-11-2014 02:15 PM |
Check out this Green+Yellow+Red FRS | Nitro | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 05-20-2013 02:18 PM |
Thoughts on a Pearl Yellow, Lime Green FR-S? | yormaX | Scion FR-S / Toyota 86 GT86 General Forum | 82 | 09-21-2012 11:21 AM |
