Old 06-15-2020, 04:15 AM   #1
Shahano
Drives: LS3 Dry Sump BRZ
BRZ LS Swap ECU
I've been running my BRZ with an LS3 swap for almost a year using the Hydra EMS system. It seemed to, along with the motec to be the only fully compatible system with ABS/Traction/ electric power steering etc.
I have had a problem with the Hydra and have been looking for alternative ECU solutions in case I decide not to continue with the Hydra. I contacted PURE for a Motec system and unfortunately they no longer produce it.
I am looking for other systems but with no luck. I have seen the previous posts and it seems that the MRS nor the PURE system are no longer available.
Could anyone recommend what system to use?
Shahano is offline   Reply With Quote
Old 06-15-2020, 04:25 AM   #2
Shahano
If anyone has a pure automotive Motec system with all the cables and is looking to sell it, I would be interested in purchasing.
Old 06-15-2020, 05:36 AM   #3
DeathToocher
BRZ LS Swap ECU
I know Haltec has an ECU that supports the GT86 CAN system, idk about the processing power compared to Motec (doesn’t really matter unless you’re running a full on race car in my opinion) but Haltec is a good company with an even better reputation from everything I’ve heard. The prices on the Haltec systems are a lot easier on the bank than Motec, so there’s another reason to go Haltec.
DeathToocher is offline   Reply With Quote
Old 06-15-2020, 05:38 AM   #4
DeathToocher
Sikky also provides engine harnesses and tuning specifically for the LS engine in the GT86 using the stock ECU. From my personal experience in planning my own swap, they run about 1200-1500.
Old 06-15-2020, 09:23 AM   #5
GrabTheWheel
Drives: 16' BRZ
Are you sure? Did you talk to Brady? Pure still has it on their website and it’s listed as in stock. Hard for me to believe he wouldn’t sell you one.
GrabTheWheel is offline   Reply With Quote
Old 06-16-2020, 03:20 AM   #6
Shahano
Do you have a contact that I can get in touch with. Haltech could be a good option, need to make sure they can provide the whole harness along with it.
Yes unfortunately, been speaking to Bradey for the past few weeks and due to a few bad customers, Motec asked them to sell only if Pure installs it for them.
Old 06-16-2020, 03:28 AM   #7
DeathToocher
I do not have a contact within Haltech, but from what see they do provide custom wiring harnesses. I would recommend going with the Sikky harness for an LS swap, they have a CANbus integration built into the harness so you can run a stock ECU I’ll drop a link real quick. https://www.sikky.com/product/gm-ls3...or-frs-brz-86/
Old 06-16-2020, 09:15 AM   #8
Shahano
Thanks a lot will have a look at it, there is a large dropdown, need to have a call with one of the guys there to understand further.
Old 06-16-2020, 05:50 PM   #9
ft86xtc
Drives: 2013 FRS
Not sure if this is what your looking for but maybe it could help.https://www.wiringspecialties.com/fr...iring-harness/
ft86xtc is offline   Reply With Quote
Old 06-17-2020, 02:09 PM   #10
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Skip Sikky- just go to WiringSpecialities direct. Sikky is just reselling their harnesses.
spitsnaugle is offline   Reply With Quote
The Following User Says Thank You to spitsnaugle For This Useful Post:
Sportsguy83 (05-09-2021)
Old 06-18-2020, 07:58 AM   #11
DeathToocher
Does wiringspecialties direct include the CANbus module and everything?
Old 06-18-2020, 02:41 PM   #12
spitsnaugle
Yes.
Reach out to them and tell them I sent you.
sales@wiringspecialties.com
My FR-S was a booth car for them at LS fest east where I won 2019 best engineered car.
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post:
B T (02-14-2023), GrabTheWheel (06-19-2020)
Old 06-18-2020, 10:29 PM   #13
DeathToocher
Yes.
Oh damn, congrats on that! I’ll have to check them out for my swap then.
Old 05-05-2021, 11:43 AM   #14
Swolzee
Swolzee's Avatar
Drives: Honda Insight
So would an ecutek work on this setup if you were using the wiring specialties harness?
Swolzee is offline   Reply With Quote
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
WRX SWAP!!! PowderfaceTr. BRZ Photos, Videos, Wallpapers, Gallery Forum 1 02-24-2015 06:29 PM
