Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
05-08-2020, 05:55 PM | #1 |
Drives: 2013 FRS
Nightmare Diagnosis - idle would pulse from 500 to 2000rpm 2-3 times then stall
Symptoms: After winter storage Reinstalled battery, drove car for around ¼ tank of gas, parked for the night, in the morning drove to work without issue. When leaving work car idled rough and had no power, put on 4 way flashers and made it home (work is a 10 min drive from home). Check engine light (CEL) did come on during drive home.
ECU scan came back with PO50A* error. Cleared error. Tried starting car, it would start, but idle would pulse from 500 to 2000rpm 2-3 times then stall. No other CEL. Solution Primary Issue: Faulty Mass Air Flow (running rich unspent fuel ran into catalytic converters) Secondary Issue: Catalytic Converters Melted which plugged exhaust *Error Code P050A is defined as Cold Start Idle Air Control System Performance. Last edited by Longuy; 05-08-2020 at 07:00 PM. Reason: attached file |
The Following User Says Thank You to Longuy For This Useful Post: | BirdTRD (05-08-2020) |
05-08-2020, 08:07 PM | #2 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
...yikes. That sounds like zero fun.
Are you able to hook the car up to a battery tender when you store it so that you don't have to remove the battery from the car? Did you put any fuel stabilizer in the tank when you stored it?
-O/D
2016 FR-S, Hot Lava |
05-08-2020, 08:37 PM | #3 |
Are your primary and secondary issues confirmed or theoretical?
The Following User Says Thank You to Tcoat For This Useful Post: | Opie (05-11-2020) |
05-08-2020, 08:51 PM | #4 |
ProCrastinationConsultant
mouse house in the exhaust?
05-08-2020, 09:14 PM | #5 |
Drives: 2013 FRS
yeah we did put fuel stabilizer in..the car was stored to far from power and on a farm.
05-08-2020, 09:25 PM | #7 |
Drives: 2013 FRS
second thing I thought of after bad gas(we siphon the gas out also)... There was a mouse nest (suspect shrew bc no wire damage) under the intake too furthering the confusion. Touge Tuning traced all the wiring harness with no evidence of chewed wires. That wasn't cheap.
05-08-2020, 09:29 PM | #8 |
And potentially the air box. Wouldn't be the first.
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (05-08-2020) |
05-08-2020, 09:38 PM | #9 |
Drives: 2013 FRS
MAF Spec is 2.21-2.69 kohms - Tested at 1.9 kohms
Here is the exhaust |
The Following 2 Users Say Thank You to Longuy For This Useful Post: | soundman98 (05-08-2020), tomm.brz (05-09-2020) |
05-08-2020, 10:11 PM | #10 |
what is it? i mean, i understand it's plugged, but with what?
05-08-2020, 10:30 PM | #11 |
Drives: 2013 FRS
It's the front pipe, with the second Catalytic converter. The first Catalytic converter carbon melted into the second, ruined the over pipe. Replaced it with a Tomei header and invidia overpipe and high flow catalytic converter front pipe. it now has that subie purr
The Following 2 Users Say Thank You to Longuy For This Useful Post: | soundman98 (05-08-2020), Tcoat (05-08-2020) |
05-08-2020, 10:38 PM | #13 |
so a mouse house wasn't all that far off
The Following User Says Thank You to soundman98 For This Useful Post: | Opie (05-11-2020) |
05-08-2020, 10:49 PM | #14 |
Well that sure ain't pretty!
Similar Threads | ||||
How to lower direct pulse width below .88 | solidsnake11 | Software Tuning | 2 | 03-29-2020 12:34 AM |
Low idle/dip and stall/loss of power | GoZ21 | Issues | Warranty | Recalls / TSB | 5 | 12-08-2017 06:50 AM |
Frs low idle dip and dies multiple times in a row | Dogster70 | Issues | Warranty | Recalls / TSB | 7 | 11-17-2017 06:44 PM |
Rough Idle/Stall/CEL/SL - next steps? | CAnemone | Northern California | 3 | 08-26-2016 12:55 PM |
Turbo Rough Idle & Stall | BRZtoni | Forced Induction | 40 | 05-25-2016 05:28 PM |
