Old 04-20-2020, 04:34 PM   #1
Kerrija
Drives: 2016 Subaru BRZ Limited
Seicane 9" Android unit.
I'm gonna go and try for this unit here and see what I get. It seems like a fairly good deal and I have seen others with Seicane units but this one seems made with the bezel included so we'll see what happens.
https://www.seicane.com/oem-android-...bd2-tpms-h2461
Kerrija is offline   Reply With Quote
The Following User Says Thank You to Kerrija For This Useful Post:
Bonburner (05-03-2020)
Old 05-09-2020, 12:24 PM   #2
Kerrija
Finally got it and worked this week on getting it installed.
On initial install everything hooked up pretty easily. I did find that my backup camera wasn't working on my 2016 but I found out why and ended up having to move the connection from one connector to another for my BRZ. Everything else seems to be quite well and it's quite responsive to touch.
Old 05-13-2020, 10:18 AM   #3
ka-titties
Drives: 2013 BRZ Limited 6MT
How's cold startup time?
ka-titties is offline   Reply With Quote
Old 05-13-2020, 01:45 PM   #4
Kerrija
It's pretty quick, just a few seconds at most. It starts faster than the old Starlink unit it replaced.
Old 05-13-2020, 02:18 PM   #5
1st86 Driver!
@Kerrija, be sure to post some photos when you have the install done.
Is there any information one where the map updates come from, or is it just using Google maps?
Also, are you planning on doing some type of wrap to make the plate match the rest of the dash?
Does it come with any harness our do you have to cut and splice?
Old 05-13-2020, 02:34 PM   #6
ka-titties
Can you post a side shot to show how far off the dash the screen is offset?
The Following User Says Thank You to ka-titties For This Useful Post:
Dadhawk (05-13-2020)
Old 05-13-2020, 02:58 PM   #7
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
that's kinda cool that it replaces the dash part of it too. there's no ugly double din pieces to fill the gap. just the whole replacement. nice.
pgranberg11 is offline   Reply With Quote
The Following User Says Thank You to pgranberg11 For This Useful Post:
Old 05-13-2020, 04:52 PM   #8
ka-titties
Aw shit. I just realized it replaces the actual dash finisher. That's NG for me
Old 05-13-2020, 06:22 PM   #9
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
I thought the exact same thing. Plus, based on the photos, the dash piece doesn't line up with the factory piece next to it, the bottom right is waaaay off.
sharpsicle is offline   Reply With Quote
Old 05-13-2020, 06:44 PM   #10
Kerrija
Oh yeah that's my bad I didn't have it seated in all the way as I was still sorting out the rear dashcam issue I had at the time.
Old 05-13-2020, 06:44 PM   #11
Kerrija
Old 05-13-2020, 06:50 PM   #12
Kerrija
It came all pre-wired. I did have to re-pin the reverse camera as the 2016 BRZ had the reverse camera in another connector so it was a matter of removing the pins from the connector they had and moving it to the other connector.
Old 05-13-2020, 06:54 PM   #13
Kerrija
It's using Google maps for the updates. It also has some other map app in there as well but I can't read Chinese to navigate the menus. Yes I'll be doing a wrap on it of some sorts to make the dash all match up.
Old 05-13-2020, 07:05 PM   #14
Kerrija
Yeah i figured I was going to have to replace the piece anyways so I thought I'd try out this instead. I have no idea what they were thinking putting that trapezoidal unit for that year. Now I gotta get some wrap to clean up the look.
Seicane S6936 Android Headunit milkydude12 Electronics | Audio | NAV | Infotainment 15 06-08-2019 12:23 AM
Hizpo 7" Android 7.1.2 head unit Rican_D Electronics | Audio | NAV | Infotainment 104 03-16-2018 05:25 PM
Android head unit drz400dude Electronics | Audio | NAV | Infotainment 6 12-20-2016 12:47 AM
200mm android head unit with android lollipop rsingh Electronics | Audio | NAV | Infotainment 3 05-23-2016 08:48 PM
How do you turn off "you have new message" notification in BRZ unit via android? Zechs21 Electronics | Audio | NAV | Infotainment 5 06-10-2014 06:56 PM
