Old 01-25-2020, 02:31 AM   #1
Payload
Drives: Raven black manual transmission
Scion gt86 owners 2013-2019
Has anyone yet began to unlock the stock potential of there gt86 vehicles ecu with an "Openflash Tablet" provided by RomRaider written software updates, or Ecu-Tek hardware..??? Please note that this doesn't apply to owners of force induction FA20 engines, explicitly meaning without the use of a turbo-charger or super-charger bolt-on to the FA20 engine block...
Payload is offline   Reply With Quote
Old 01-25-2020, 11:55 AM   #2
bfrank1972
Drives: 2013 FR-S Argento
Yes
Sent from my SM-G965U using Tapatalk
bfrank1972 is offline   Reply With Quote
The Following 4 Users Say Thank You to bfrank1972 For This Useful Post:
DarkPira7e (01-25-2020), Spuds (01-29-2020), The Red One (01-25-2020), weederr33 (01-31-2020)
Old 01-25-2020, 02:20 PM   #3
Payload
Cool, so have you approximated and determined your performance results. If you don't mind me asking what are your guesstimated power and torque out-put ratings from the fly wheel..😀
I have an idea of where my performance ratings stand ;even though I haven't dyno tested the car.. I'll share my values and tell you how I arrived at my guesstimated numbers..
Old 01-25-2020, 03:41 PM   #4
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
This is going to be good...
The Following 7 Users Say Thank You to KR-S For This Useful Post:
finch1750 (02-06-2020), korhun (01-29-2020), NWFRS (01-25-2020), ROFL it's Waffle (01-29-2020), Spuds (01-29-2020), Tcoat (01-25-2020), Tristor (01-29-2020)
Old 01-25-2020, 03:43 PM   #5
strat61caster
strat61caster's Avatar
+5 hp tune
+5 hp header
ineedyourdiddly
Old 01-25-2020, 03:50 PM   #6
Payload
I guess this was all you did so far..
Did u try uploading tunning software yet ?
I have done the following :
1. Performance equal length headers
2. Permance Full cat back exhaust
3. Aluminum drive shaft
4. Turbo fuel pump that can displace fuel at 365Lph I think I gotta re-check that spec.
5. K&N drop box air filter
6. Openflash tablet tune, I just started customizing my own tunes for this hardware like 2 years ago, after learning more.
Old 01-25-2020, 04:01 PM   #7
KR-S
Sporadic Member
KR-S's Avatar
I just caught this gem:
This FA20 engine is capable of over 300 hp on just tuning the software via "openflash"or "ecu tek" without any force induction bolt-ons, I did some research with other forums discussed about this matter and just to make sure what I read was accurate I did some checks and checked out some numbers with an online fuel injector calculator, after using it myself I can provide some valid testimony to this subject matter myself.. The only the problem with a tune for this car minus any bolt- on force induction system is the torque rating.. Your not going to pick up extraordinary torque rates in the low rpm tech region say btwn 2,000-3,000rpm gauge until you get to about (X~>4,800)rpm or past it, the force induction has an advantage at high torque out-puts in the very low rpm region, that maybe the sole purpose of even using force induction. It's a waste of time of doing force induction just to say that your car can do 300+ hp because a stand alone tune will give the same power output in the higher rpm region of the techcometer..That's probably why Toyota reps took so long to even consider a turbo.. The power gains are solely in the users tunning capabilities for 300+ without using any force induction bolt-ons to the engine... Based on what I've noticed, force induction for a stock FA20 engine would only make sense if your trying to put on extra 200hp to the fly wheel or drag racing purposes.. Enjoy my friends����
300hp with just a tune
DarkPira7e (01-25-2020), ElijahF (01-25-2020), NWFRS (01-25-2020), ROFL it's Waffle (01-29-2020), soundman98 (01-25-2020), Spuds (01-29-2020), Tristor (01-29-2020)
Old 01-25-2020, 04:03 PM   #8
Lantanafrs2
Drives: 2013 frs red
Oh lord
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
KR-S (01-25-2020)
Old 01-25-2020, 04:09 PM   #9
Payload
What is that image in your reply box ??
Old 01-25-2020, 04:21 PM   #10
KR-S
Sporadic Member
KR-S's Avatar
The Twitch emote OMEGALUL, a twisted image of the late John Bain aka TotalBiscuit, whose original image is also used as the LUL emote on Twitch. Used to express when something is really, really funny.
Millenial/Zoomer humor, basically.
The Following User Says Thank You to KR-S For This Useful Post:
NoHaveMSG (01-25-2020)
Old 01-25-2020, 04:21 PM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
This is like 'Back to the Future' but without the 'Future' bit..
The Following User Says Thank You to JD001 For This Useful Post:
Old 01-25-2020, 04:40 PM   #12
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Does ECU-TEK offer financing?
NWFRS is offline   Reply With Quote
The Following 3 Users Say Thank You to NWFRS For This Useful Post:
bcj (01-25-2020), KR-S (01-25-2020), soundman98 (01-25-2020)
Old 01-25-2020, 04:56 PM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I can't believe so many of us wasted our time with stupid turbos and Superchargers. The answer was within our reach this whole time- methamphetamine!
The Following 11 Users Say Thank You to DarkPira7e For This Useful Post:
Alpha86 (01-27-2020), BigHugeFatGuy (01-28-2020), DandoX (01-29-2020), korhun (01-29-2020), KR-S (01-25-2020), NoHaveMSG (01-25-2020), ROFL it's Waffle (01-29-2020), soundman98 (01-25-2020), Spuds (01-29-2020), SuperTom (01-27-2020), Tristor (01-29-2020)
Old 01-25-2020, 04:58 PM   #14
KR-S
Sporadic Member
KR-S's Avatar
Looks like all the tuning shops gotta start opening meth labs and hire some science teachers.
My Toyota GT86 Lapis Blue 2019 Alastor FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 03-06-2020 04:13 AM
Openflash Tablet for GT86 – Scion FRS, Subaru BRZ, Toyota 86 (2012 to 2019) Redline360 Engine, Exhaust, Bolt-Ons 0 08-05-2019 10:28 PM
2018 vs 2019 gt86 krossfyah Scion FR-S / Toyota 86 GT86 General Forum 8 02-21-2019 06:50 AM
WTB: 2013 Scion FR-S Owners Manual Kicker18 Want-To-Buy Requests 2 01-10-2017 02:30 PM
Toyota GT86 / Scion FR-S Convertible Rumored for Geneva Debut in March 2013 Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 61 11-27-2012 08:50 AM
