Old 01-17-2020, 02:58 PM   #1
George Rosebush
Drives: 2015 Scion FRS
Was planning on using stock tires, but punctured one, so now what?
As the title states, I was planning on using my stock tires for a number of trackdays as I learn, but on lap 1 session 2 of day 1 at Chuckwalla I badly punctured one, ended the day, had to crawl back on the spare donut to a tire shop. The tire I bought I thought was all season but is actually a Kumho summer tire.
Anyways, so much for that plan, as after what happened I'm definitely bringing an extra set of track only wheels and tires, so the question is what type. I'm leaning towards R compound tires such as the Nitto NT01, and I know the argument that a beginner shouldn't use such grippy tires, but I also don't want to buy tires only for the track that aren't, uhh, only for the track. I don't expect to ever do a trackday in rain, I don't care about being competitive, and I don't like the idea of learning on mismatched low grip all season tires.
The one session I did was on my all seasons, Goodyear Eagle Sports in the stock size, and I don't know if my lack of confidence in them was just my own lack of experience or if there really is no lateral grip, because that's what it felt like. Again, that could just be me not being used to cornering at speeds, but I would definitely like to feel more mid turn grip.
George Rosebush is offline   Reply With Quote
Old 01-17-2020, 03:12 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Pretty much all the 200tw tire category would fit your need. Why pigeon hole yourself into such a polarized setup? Pick one or the other, you can't both learn on a forgiving tire and also decide you're going to be a gripmaster right out of the gate.
The Following User Says Thank You to DarkPira7e For This Useful Post:
Mr.ac (01-17-2020)
Old 01-17-2020, 03:24 PM   #3
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Hankook RS4, my last set lasted 20 trackdays and they aren't much slower than an NT01. They take the heat well and have great characteristics.
14stu is offline   Reply With Quote
The Following 2 Users Say Thank You to 14stu For This Useful Post:
George Rosebush (01-17-2020), ZDan (01-17-2020)
Old 01-17-2020, 03:49 PM   #4
George Rosebush
Thanks, what size would you say for a 17X8 wheel? They don't come in the ideal sizes.
Old 01-17-2020, 03:54 PM   #5
14stu
14stu's Avatar
245 would be optimum, but you can run anything form 225 to 255 without issues. They haven't shipped this year's run so there are only limited sizes and quantities available right now.
Old 01-17-2020, 04:01 PM   #6
George Rosebush
245 would be optimum.
Are these a continuation of the RS3?
Old 01-17-2020, 04:08 PM   #7
14stu
14stu's Avatar
They are the replacement for RS3, they have much higher grip levels but give up some of the heat tolerance (still hard to overheat but the RS3 could take a blowtorch and keep going).
They out last other 200tw tires and only give up grip to the RE71r. They are similar to the Falken 615k+ but last nearly twice as long and have slightly more grip.
The Following User Says Thank You to 14stu For This Useful Post:
Old 01-17-2020, 04:13 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If the goal is to learn then buy the best tire for that. Dont get stuck on needing a "track tire" for track wheels. I have become a much better driver when I went to something less grippy than the RS3 I started on.
GT Radial SX2 would be awesome for you. Decent grip, takes abuse, great feedback, last a long time.
86_IT (01-17-2020)
Old 01-17-2020, 04:22 PM   #9
86_IT
86_IT's Avatar
If the goal is to learn then buy the best tire for that. Dont get stuck on needing a "track tire" for track wheels I have become a much better driver when I went to something less grippy than the RS3 I started on.
I second this and also add that they are very affordable compared to the other "track tires".
Instagram: 86_IT Twitter: 86_IT_BRZ Facebook: 86itbrz Youtube:86 IT
86_IT is offline   Reply With Quote
Old 01-17-2020, 04:48 PM   #10
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Flat tires are super rare so I wouldn't get another set of wheels just for that reason.
If you are just getting started in tracking your car then just get another stock tire, or go with a "normal" summer street tire. I can highly recommend Michelin's MP4S.
Definitely DO NOT get stickier track tires if just starting out; they will mask mistakes and will increase corner speeds which will make it harder to catch mistakes. I wouldn't even recommend 200TW tires for someone getting started since these can be as sticky as DOT R compound track tires.
Sleepless is offline   Reply With Quote
Old 01-17-2020, 04:57 PM   #11
George Rosebush
Those cost the most out of all the suggestions here.
Old 01-17-2020, 06:38 PM   #12
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Cheaper than two sets of wheels/tires...
Old 01-17-2020, 06:40 PM   #13
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Nt01s and most track tires a very loud for street driving ...
Old 01-17-2020, 06:43 PM   #14
George Rosebush
One set, I already have the one set for daily driving. So comfort/loudness wouldn't matter either.
Remove P4S tires from my stock BRZ PP wheels and mounting snow tires? jredders Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-25-2019 11:30 PM
Oil filter punctured wrap, does it matter? BayBRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 08-05-2016 01:26 AM
FS (GA) 15 BRZ Stock Wheels + Tires + TPMS + stock lugs & locks (tires 10k miles) GTHachiRoku Wheels and Tires 15 07-30-2016 11:51 AM
Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? fooddude Engine, Exhaust, Transmission 39 12-15-2013 02:05 PM
