01-10-2020, 05:30 AM | #1 |
Drives: turbo frs
white smoke
Dear
I have turbo frs From the first tune (Dyno tune) To the second remote tune (online) I noticed that when I put gear for example at 3rd gear and rpm Lower than 3k some withe smoke coming from exhaust . What could be the issue ?? Thnx |
01-10-2020, 07:12 AM | #2 |
White smoke is coolant.
Blue smoke is oil. Black smoke is fuel. White and Blue smoke look similar. Have you had a chance to smell the smoke. Coolant will have a sweet smell, oil will smell like.... burned oil. |
The Following User Says Thank You to Grady For This Useful Post: | YamahaR86 (01-10-2020) |
01-10-2020, 07:48 AM | #3 |
Drives: 2017 BRZ w/PP
yep thats coolant so your either cracked your block or blew a head gasket
01-10-2020, 10:12 AM | #4 |
Drives: turbo frs
01-10-2020, 11:06 AM | #5 | |
have you tested it to make sure? it might be a very minor leak under high load. does the smoke stick around or go away pretty fast like when you start a car in the cold? |
01-11-2020, 02:52 AM | #6 | |
Drives: turbo frs
My dear This just happened at low rpm Or when I shift to reverse . Just for few seconds and gone when rpm go up I think it is maf scaling issue Steve any thing from your side |
01-11-2020, 07:26 AM | #7 |
Very unlikely to be a tune related problem unless it was black fuel smoke
Smoke is most likely oil, but possibly coolant Coul be turbo seals Catch can routing issue PCV vavle or check valve issue Rings valve guides worn broken Overfilled oil Blocked or restricted turbo oil return Check turbo intake for oil Overoiled air filter Probably a few others It only takes a small amount of oil to see smoke might take a fair bit of driving before you see levels drop. |
The Following User Says Thank You to steve99 For This Useful Post: | gt7877 (01-12-2020) |
Similar Threads | ||||
Burning smell and white smoke | Tacticalpanda | Issues | Warranty | Recalls / TSB | 21 | 10-12-2018 09:56 AM |
White smoke decelerating | azynneo | Engine, Exhaust, Transmission | 6 | 07-23-2016 10:14 AM |
Cloud of white smoke on startup | wawro569 | Issues | Warranty | Recalls / TSB | 25 | 01-16-2015 12:55 PM |
White smoke in Engine bay | Pinoywhiz | Engine, Exhaust, Transmission | 7 | 04-07-2014 06:10 PM |
White smoke coming from the exhaust. | hansthegerman | Engine, Exhaust, Transmission | 17 | 10-02-2013 04:23 PM |
