Old 11-28-2019, 11:05 PM   #1
KooshaS
Drives: 2017 Subaru BRZ Premium
Gaskets for overpipe?
Hey y'all i have a front pipe and catback installed on my brz currently and want to install a header and overpipe in a few weeks. I bought some grimspeed header gaskets already but i was wondering if i should replace the gaskets that go on either side of the overpipe as well?
KooshaS is offline   Reply With Quote
Old 11-28-2019, 11:10 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Might as well since the new overpipe and header will come with some
MS, CSCS, TSAC-F, CPT
Old 11-29-2019, 01:58 PM   #3
KooshaS
Got both the headers and overpipe used with 2k miles on them so i gotta buy the gaskets separately.
Old 11-30-2019, 01:45 AM   #4
juniorrr
Drives: Scion Frs
You might as well while your already down there, since gaskets eventually go bad over a long period of time putting a new one now could save you the hassle later on if one were to go bad.
juniorrr is offline   Reply With Quote
Old 11-30-2019, 01:57 PM   #5
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
https://www.amazon.com/Remflex-6005-...74268951&psc=1
if you haven't purchased already I recommend these. Overpipe connections are notorious for getting leaks, and these are the thickest gaskets I've had out of any supplied invidia, oem, or grimmspeed I've tried.
MCTeeJ is offline   Reply With Quote
Old 06-17-2020, 01:51 PM   #6
mfragoso18
Certified Ricer
mfragoso18's Avatar
Drives: 2015 FRS Release Series 1.0
Any updates on them, thinking of ordering them rn.
mfragoso18 is offline   Reply With Quote
Old 06-18-2020, 09:50 AM   #7
MCTeeJ
MCTeeJ's Avatar
They were holding up fine going on about a year, but my exhaust bolts peaced out about a month ago and the leak destroyed them. I replaced them with the same stuff along with some brand new bolts/lock nuts and the exhaust is once again sealed up.
Old 07-19-2020, 01:45 PM   #8
KimEatsGlue
Drives: 2017 GT86
Does anyone know if these specific gaskets have an orientation? Which side faces forward?
KimEatsGlue is offline   Reply With Quote
Old 07-19-2020, 01:57 PM   #9
Compelica
Compelica's Avatar
Drives: 86 GT
IINM the gaskets have tabs at the ends which should tell you the orientation - make a note of the old gasket's tab positions when you pull off the overpipe.
Compelica is offline   Reply With Quote
FS NJ: Borla UEL V2 Header & New Invidia Overpipe with Gaskets elitegunslinger Engine, Exhaust, Bolt-Ons 10 07-11-2017 09:54 AM
Borla UEL header, motiv overpipe and gaskets Infidel86 Engine, Exhaust, Bolt-Ons 14 11-01-2016 03:00 PM
Stock exhaust gaskets/Perrin 3" gaskets migx333 Engine, Exhaust, Transmission 1 07-10-2015 11:23 PM
Help: Overpipe back--replace which exhaust gaskets? OnTheFence Engine, Exhaust, Transmission 1 09-28-2013 12:18 PM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
