Engine Swaps Discussion of engine swaps. |
10-14-2019, 08:59 AM | #1 |
Drives: Toyota 86
Help 2jz swap M/T in Toyota 86 A/T
hey guys
I apologize if I didn't ask my question in the right place i have a question about 2jz swap i have 2017 toyota 86 A/T and i wanna swap to 2JZ Manual Trans just i wanted to know what the problems would be in this swap How's that?and how to ? thanks guys |
10-14-2019, 10:15 AM | #2 |
Drives: 2017 series yellow BRZ
whats your budget? for the most part 30-35k is basically bare minimum.
My BRZ Build Thread
http://www.ft86club.com/forums/showt...17#post3079417 |
The Following User Says Thank You to Greenbean For This Useful Post: | Pouria (10-16-2019) |
10-14-2019, 06:04 PM | #3 |
Drives: Toyota 86
10-14-2019, 06:14 PM | #4 |
Rust bucket enthusiast
If you even remotely understood the implication or context of your own inquiry you wouldn't be asking.
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post: | Leonardo (10-14-2019), NWFRS (10-16-2019), Tcoat (10-16-2019), TunaNoCrust (10-16-2019), wparsons (10-15-2019) |
10-15-2019, 05:11 PM | #5 |
Are you doing the swap yourself, or paying a shop? If you're paying a shop, you should be asking them. If you're doing it yourself, good luck, this will be one of the easier parts of the swap.
The Following User Says Thank You to wparsons For This Useful Post: | Pouria (10-16-2019) |
10-15-2019, 05:45 PM | #6 |
Drives: WORKS CARB Legal Turbo BRZ
There is going to be a lot of issues you're going to have to deal with. For the clutch system, you will need a new pedal assembly with clutch pedal. Then you will have to mount a clutch master cylinder and reservoir. After you've got that going it is going to be a fun project making a drive by wire system work. I'm not even sure how this would be accomplished. It may be easier to completely switch to a Tilton pedal setup as that would solve both of these issues so far. Of course, you will need a custom drive shaft and probably make a shifter cut out. Then there is the wiring. Thats going to be scary. I wouldnt even know how to begin with that. Getting diagrams for both engine and chassis would be a good start. Have highlighters and pens ready and get to matching wires. It is going to be a lot of hard work and even more money. Good luck with it all.
The Following User Says Thank You to WORKS For This Useful Post: | Pouria (10-16-2019) |
10-15-2019, 06:01 PM | #7 | |
Drives: 2017 toyota 86
Step 2. Buy M/T Supra Swap complete. On a serious note. The A/T to M/T conversion is the least of your concerns, since you will be buying a new trans, drivetrain, etc... already regardless. But the swap itself is a lot of work. So much so that the need to ask this question probably takes you out of the very very few individuals in this world where a swap like this makes sense. Built FA20 shortblocks are pretty cheap if you can DIY everything yourself besides a tune you can be at a fun safe reliable 450whp for around $15k. If you want a M/T trade your car in for one. Or you can build the AT to handle 400ft lbs with clutch pack, valve body, torque converter for $3-4k more. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Pouria (10-16-2019) |
10-16-2019, 05:28 AM | #8 | |||
Drives: Toyota 86
If I could buy M/T car, I'd buy it. But there are problems that make this impossible for me. I know one Tuning Group doing this for a few other 86. But they were M/T If I want to do it, I'll get help from them btw thanks for your help Quote:
yeah i know it's huge and needs hard and hard work and of course money but i didn't do anything yet... I just started gathering info and experience thanks Quote:
thanks |
10-16-2019, 07:26 AM | #9 |
The Following User Says Thank You to Tcoat For This Useful Post: | wparsons (10-16-2019) |
10-16-2019, 09:36 AM | #10 |
Drives: 2013 frs red
Troll thread
10-16-2019, 09:39 AM | #11 | |
My BRZ Build Thread
10-16-2019, 10:02 AM | #12 |
10-16-2019, 10:12 AM | #13 | |
he says he has a manual in that thread, but auto in this? |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | wparsons (10-16-2019) |
10-16-2019, 10:15 AM | #14 | |
What would limit you from trading in and/or selling your 86 to buy a different one with a M/T already in it? New and or lightly used BRZ/86 M/Ts are all over the place. |
Tags |
2017 86, 2jz swap, toyota 86 |
Similar Threads | ||||
Toyota 2AZ-FE Engine Swap | srscion | Engine Swaps | 54 | 10-26-2020 11:13 PM |
FRS to Toyota 86 emblem swap | amartinez9881@gmail.com | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 03-15-2016 05:03 PM |
Swap Emblem: FRS -> Toyota | simplychrispy | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 02-25-2015 12:14 PM |
Toyota left a nice surprise if you're doing a Toyota motor swap.. | Manji | Engine Swaps | 15 | 01-07-2015 01:48 AM |
Toyota MR2 motor swap | Abflug | Other Vehicles & General Automotive Discussions | 18 | 01-12-2011 06:12 PM |
