Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-17-2019, 09:13 PM | #1 |
Drives: '14
Added E85. Ethanol Gauge didn't change?
Using Moto East's Flex fuel kit. I've been tuned for it as well. I added 11 gallons of E85 for the first time and started up my car. The car drives fine but my digital ethanol display gauge didn't change. Drove 2 miles home after that and it still didn't change.
Any suggestions? :/ |
07-17-2019, 09:21 PM | #2 |
TRACKBREAD
Keep driving, it takes more than 2 miles
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post: | DarkPira7e (07-17-2019), kev0 (07-17-2019) |
07-17-2019, 09:25 PM | #3 |
Drives: '14
The Following User Says Thank You to kev0 For This Useful Post: | Yoshoobaroo (07-17-2019) |
07-17-2019, 09:33 PM | #4 |
TRACKBREAD
Yea on my oft it takes almost 10 miles for my fuel trims so change.
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | kev0 (07-17-2019) |
07-17-2019, 09:42 PM | #5 | |
Drives: 2015 Subaru BRZ Series.blue
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
The Following User Says Thank You to Strife26 For This Useful Post: | kev0 (07-17-2019) |
07-17-2019, 11:14 PM | #6 |
The ethanol percent should start to change on guage in first few e of miles. Two might be a bit short but if you do 5 and nothing changes its a bit unusual
It may depemd on the port to direct injection ratio as you have to put your sensor in either the di or the port feed line. If your tune uses a lot of di down low put in di if it uses a lot of port put it in port line. If its rear 02 flex kit log the rear 02 sensor volts, close to 0 volts means zero ethanol, close to 5 v means close to 85% ethanol in most cases |
The Following User Says Thank You to steve99 For This Useful Post: | kev0 (07-17-2019) |
07-17-2019, 11:51 PM | #7 |
What is your ecutek log seeing?
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | kev0 (07-17-2019) |
07-18-2019, 12:00 AM | #8 |
Drives: '14
Similar Threads | ||||
Flex Fuel Gauge and Boost Control based on Ethanol Content | DeliciousTuning | Forced Induction | 6 | 10-11-2022 05:37 PM |
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 12:48 PM |
Gauge Lights Change Color In Traction Off Mode | dkrou351 | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 04-18-2013 08:49 PM |
Everything I didn't like about the BRZ... | Laika | BRZ First-Gen (2012+) -- General Topics | 40 | 06-28-2012 11:00 AM |
Nothing we didn't already know | 315FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-24-2012 11:06 PM |
