Software Tuning Discuss all software tuning topics. |
Drives: 2013 MY14 Toyota gts86 Turbo
ADMIN PLEASE STICKY
Bee*R 25th Anniversary Power Module Type B - Toyota GTS86 SMART ENTRY Tools you will need: -Wire Stripper (a must) -Electrical Tape (a must) -Heat Shrink (not a must) -Soldering Iron (a must) -Solder (a must) -Newspaper (a must) -Heat Gun/Cigarette Lighter (not a must) -Once your Bee*R arrives, ignore the Wiring Diagram instructions for the Smart Entry 86 System and follow my Guide. -My guide is what works for me AFTER trying for about 10 weeks to get my Bee*R working because the Wiring Diagram and instructions that were given for the install did NOT at all work for me. Mind you.. when i say 10 weeks, I tried many ideas, this and that and I can honestly say my guide is what works, at least for me (Smart Entry). -I had asked a fair few amount of people for help and I got people where they didn't know what Bee*R was and people where they knew about them or had one themselves but the Bee*R wouldn't operate properly like it should or it didn't operate at all. The Official Steps in order to make your Toyota GTS Smart Entry - SHOOT 4 FOOT FLAMES!!! IMPORTANT NOTES: -It's important that you DO NOT fix your Bee*R to a position/location until you have tried and tested your Bee*R. 1. We need to locate the 5 wires coming from our Bee*R onto our -Yellow - IGNITION. CYLINDER 2.OUTPUT -Grey - Launch Control Handbrake/Clutch -Red - 12v+ -Black - Ground -Green - NE+ Engine Speed/Crankshaft Angle Position Sensor -These wires coming from the Bee*R will come already stripped for your convenience. 2. We need to locate the 5 wires that i previous said earlier in step 1, onto the ECU behind the Glove Box, our ECU has 4 plugs. We will be using only 2 of these plugs and they are: A36 plug 34 pinouts: -Black Wire - Pin 4 -Yellow Wire - Pin 31 A34 plug 35 pinouts: -Green Wire - Pin 16 -Red Wire - Pin 6 Wiring Diagram link for the ECU Pinouts: -http://www.ft86club.com/files/BRZwiringi.pdf on Page 389 -The Grey wire we use as our Launch Control - You can utilise your launch control for either: -Your handbrake signal wire or for your clutch signal wire. -By having your Grey Wire Launch Control wire going to the Clutch signal wire you wont need to lift up between gears, this will engage FFS=Flat Foot Shifting. -In Boosted applications this is specially helpful while this keeps us in the positive boost areas. Good To Know: Switches on the side: -Switch 1: OFF -Switch 2: OFF -Switch 3: OFF -Switch 4: ON Dials on the front: -Rev 1: Redline (Left Dial) -Rev 2: Launch Control (Middle Dial) -GAIN: Fast and Slow frequency of spark/ignition cut 1-F (Right Dial) -1 Being the fastest spark/ignition cut = Bapapapapap -F being the slowest spark ignition cut = BANG BANG BANG -For some.. the sweet spot is 9, for some the sweet spot is on a later GAIN. Have a play. -Between all 3 DIALS you will need to find that sweet spot for you and your car, and what you plan to perform with your Bee*R, whether its for show, or a perfect launch etc. Throwing CEL Codes? -No codes should show but if they do, make sure you have an OBD-II port device Code Reader to clear the thrown codes and try a different GAIN. -Codes also may throw from operating the Bee*R too often at one given time or perhaps in quick intervals. -In all honesty I think the Bee*R is mainly great for pleasing an audience of flames. -If you're reading this and you have your Bee*R working or know a friend or someone who has their Bee*R working on a NON-SMART ENTRY 86 system, please pm me or message me here and I'll add the instructions here and give you credit, just so all the information is in one place. -Or If you're a person who has a Bee*R and you're a NON-SMART ENTRY System 86 and the unit doesn't operate, I may have a wiring Diagram for you that is untested but could just work but at your own risk but hey life is full of taking risks. -I am not held responsible for anything that blows, this is my guide that safely works for me, use at your own risk. -Pictures can be provided if a written explanation is not clear enough. Have Questions? Follow me on: Instagram: Phoenix_gts86 Last edited by Phoenix_gts86; 06-26-2019 at 05:51 PM. |
The Following 4 Users Say Thank You to Phoenix_gts86 For This Useful Post: |
![]() Sent from my iPhone using Tapatalk
Bee*R 2-Step [INSTALL GUIDE] http://www.ft86club.com/forums/showt...94#post3231194
Instagram: phoenix_gts86 |
The Following User Says Thank You to Phoenix_gts86 For This Useful Post: | stefodrom (07-05-2019) |
Drives: GT86 AT 2013
Hi Buddy! Thanks for sharing your instructions.
Can you upload a video for us? i can't find something on yt. Is the Bee R only using Cylinder 2 for ignition cut? Why especcially cylinder 2? Thanks! |
#4 | |
Hey stefodrom, I’m on Mobile and have the content footage and everything on my Mobile using Tapatalk, is there a way to upload videos in replies? This is just so I can share the videos. I’m yet to discover why this is what it is, this signal output for the cylinder 2 is what works for me so I’m going with it ![]() Sent from my iPhone using Tapatalk
The Following User Says Thank You to Phoenix_gts86 For This Useful Post: | gt7877 (09-03-2019) |
Drives: turbo frs
Thnx alot for this thread
Can u plz explain how I can fix bee r at my scion frs (turbo) No smart entry |
#6 | |
Do you have Instagram? I can pm you to help you Sent from my iPhone using Tapatalk
Drives: turbo frs
How many times have I used the bee*r? Sent from my iPhone using Tapatalk
Nah mate that half snapped and broken off, either that or someone ripped it off clean. Sent from my iPhone using Tapatalk
#10 | |
A low rev limit without cutting fuel, to cut ignition spark would be the ideal situation here. A cheap alternative is to go with ecutek and create custom maps to have them all activate on launch control. An expensive alternative is to go with a PnP Standalone ECU that offers the Motorsport feature Anti-Lag. For what you’re doing can only work while stationary? Sent from my iPhone using Tapatalk
#11 | |
What PnP do you have? Sent from my iPhone using Tapatalk
#12 | |
Cool no problem I’ll pm you as there are a few things to check as well Sent from my iPhone using Tapatalk
#13 | |
I have pmd you Sent from my iPhone using Tapatalk
#14 |
Drives: turbo frs
Dear
Can u plz attached some pictures for wireing and location of each wire This could help as alot 2morrow I'll get my bee rev So I need some help with it MT turbo FRS Thnx again |
Tags |
2step, bee*r, flames, tuning, turbo |
Bee*R Rev Limiter Power Module 25th Anniversary | Phoenix_gts86 | Electronics | Audio | NAV | Infotainment | 2 | 06-26-2019 09:36 AM |
Smart entry not working | viper073 | Electronics | Audio | NAV | Infotainment | 6 | 07-31-2018 12:10 PM |
FRS, Lost key and keyless entry module | roggt86 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 12-29-2014 08:35 AM |
Help! smart key/keyless entry disabled | deadsailor86 | Electronics | Audio | NAV | Infotainment | 0 | 09-17-2014 02:58 PM |
Aftermarket Push Button Ignition Smart Entry System | zAnSh1n | Electronics | Audio | NAV | Infotainment | 75 | 08-19-2012 02:23 PM |
