Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-07-2019, 06:05 PM | #1 |
Drives: 2018 BRZ tS
Electronic exhaust valve control
Hey
I plan to buy an exhaust system for my BRZ soon. I do prefer to have control over the exhaust loudness like in my previous BMW. However, I'm inexperienced with car modding in general. Is there a way to install an electronic exhaust valve control on an after market exhaust? Should I go to a local shop and get a custom exhaust built with that module? or is it possible to install it on any muffler? All what I want is to have the option to keep it quiet (so I don't wake people up at night). If the answer to the above is "NO" .. is it worth installing an after market exhaust for performance gains? or is it purely for sound on these cars? Before installing an exhaust, I'm getting an OFT + UEL header. |
The Following 2 Users Say Thank You to TOtS For This Useful Post: | brzboy (06-12-2019), ROFL it's Waffle (02-06-2020) |
06-07-2019, 06:41 PM | #2 |
[insert cool phrase here]
Drives: BRZ Premium
Yes.
Yes. It's all for sound. Hardly any hp gains with tune and headers. Some people think peak hp translate to useable power. Google, or searching could have given you your answer faster than my typing. Also I highly recommend you sell your car and go back to BMWs.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following User Says Thank You to Mr.ac For This Useful Post: | x808drifter (06-07-2019) |
06-07-2019, 07:12 PM | #3 |
LMGTFY
Drives: 13 FRS, 91 Miata
No.
No. It'll give you LARGE hp gains with/out tune and headers. It's a fact that peak hp translates to usable power. Google, or searching could have shown I'm full of crap faster than my typing. Also I highly recommend you sell your car and go back to BMWs. ^ Except that. That I agree with 100% |
The Following User Says Thank You to x808drifter For This Useful Post: | Mr.ac (06-07-2019) |
06-07-2019, 07:26 PM | #4 |
If you can't go fast go loud.
On these cars the input to the muffler and one of the outputs are close together. A good shop can put a bypass with an electric valve. |
06-07-2019, 08:10 PM | #5 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Google Varex mufflers and QTP (Quick Time Performance) cutout valves then go talk to a good exhaust shop, but you're probably better off piecing together a nice setup as there are lots of options for this platform.
A header and a tune is a good place to start, but most importantly, search this forum, the wisdom you seek is all here grasshopper. |
06-07-2019, 08:48 PM | #6 | |
I'm a bit confused as to why you are changing your exhaust system - If you are looking for just an increase in sound, an axle back or cat back modification will do that. If your looking for a bit more power, a header and tune will do that. If you are happy with the present sound and performance and you just want to make a lot of racket from time to time, any muffler shop will fix you up with a cut-out. Your call - humfrz |
06-07-2019, 09:31 PM | #7 | |
86
Here ya go; https://vandemonperformance.com.au/p...-stainless-exh or https://www.vividracing.com/exhaust-...151444040.html |
The Following User Says Thank You to Boomerang For This Useful Post: | humfrz (06-07-2019) |
06-07-2019, 10:44 PM | #8 | |
Drives: 2018 BRZ tS
I would go back to BMWs if they had cars under $50k that are as fun as a BRZ |
06-07-2019, 10:45 PM | #9 | |
Drives: 2018 BRZ tS
Are you recommending keeping the stock system and just installing a bypass to get a muffler delete sound on demand? |
06-07-2019, 10:53 PM | #10 | |
Drives: 2018 BRZ tS
With modding the car overall I'm looking for better acceleration (and hopefully eliminate the torque dip). I'm not sure if the exhaust can help with that, but I would also enjoy a nice sound when driving. |
06-07-2019, 11:34 PM | #11 | |
Not that these modifications are going to plaster you against the back of your seat nor make it sound like a finely tuned race car. The downside is that these modifications cost money, a catless system may get you into trouble with air quality regulations in your area and you may be denied certain warranty work if it pertains to the engine. I'd recommend a free-er flowing, drop in air filter and a modest sounding catback or axle back muffler system. Now, I also understand that if you want to get any significant power gains from a FA20 you have to force feed the engine. humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | TOtS (06-08-2019) |
06-09-2019, 10:03 PM | #12 |
Drives: 2005 Toyota Camry
some exhausts already have an electronic exhaust valve/bypass built in, you just need to determine what you want to bypass before deciding on what to buy.
06-09-2019, 10:47 PM | #13 |
ProCrastinationConsultant
i've been watching this thread in hopes that there's a solution somewhere i haven't found. i want the oem exhaust sound, but also want the capability to switch to another exhaust that's got some more of my own preferred version of noise.
06-09-2019, 11:00 PM | #14 | |
Drives: 2017 Subaru BRZ Limited
Here's what you need to know: 1. The only exhaust component that provides a useful performance improvement when changed is the headers. Doing this also requires you to run a tune. Headers + e85 tune is worth ~28whp. 2. You can leave everything stock except the headers and it's about as quiet as its going to be with catless headers. 3. Yes, you can have an exhaust shop weld in an electronic cut out and wire up a switch. This can be done to your stock exhaust or to any aftermarket exhaust. 4. There is no benefit to running no muffler, so running a cutout on this platform is basically dumb, but if you want to make it loud with a switch, go for it. Straight piped 4-bangers sound like shit though. 5. You should definitely buy another BMW. The new Z4 coupe (Supra) looks nice. |
The Following User Says Thank You to Tristor For This Useful Post: | TOtS (06-10-2019) |
Similar Threads | ||||
HKS Legamax Resonator Delete? Edit: electronic cutout valve? | Raven86Project | Engine, Exhaust, Transmission | 7 | 05-24-2019 02:04 AM |
FRS/BRZ ELECTRONIC BOOST CONTROL | 671mike | Forced Induction | 6 | 06-05-2018 06:07 PM |
Big brake kit and electronic vehicle control | banane63 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-22-2015 08:33 PM |
electronic boost control. | Jaden | Forced Induction | 10 | 02-02-2015 11:28 AM |
Electronic Heating and AC control in FRS | cagster | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 04-08-2013 09:09 AM |
