Engine Swaps Discussion of engine swaps. |
05-22-2019, 02:35 AM | #1 |
Drives: 2013 Subaru BRZ
e85 problem. Meter showing e40, not e80
Just filled my car with e85 completely at the new Wawa where i live.
The ethanol meter should show e80+ but it only shows e40. Is this a problem with my ethanol meter or is the pump itself? I haven't filled my car with e85 in over a year since the the place near me closed down but now a new place just opened. |
05-22-2019, 07:15 AM | #2 |
I Love custom Turbo kits
Drives: Limited BRZ
Most probably a bad batch of E85. In my area, E85 usually ranges from E60-E78, maybe four times in three years I ever saw E82 and once I saw about E87.
IF your tank wasn't completely drained, the remaining pump gas (E10) also contributes to the number being lower.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Irace86.2.0 (05-22-2019) |
05-22-2019, 08:00 AM | #3 |
2 ugga dugga's
Drives: Nike
Buy an e85 tester and test the station, they are cheap
Want to 2JZ swap your 86? Click here first!!
The Following User Says Thank You to Clash0901 For This Useful Post: | wparsons (05-23-2019) |
05-22-2019, 10:32 AM | #4 |
Drives: Q5 + BRZ + M796
Agreed with the others, but also, most stations say E50-E85 or something, and they fluctuate depending on the time of year. In Philly, I bet they run a lower mix during the winter than we do in California or cold starts would be a bitch. That, on top of the fact that no one is ever empty when they fill up. Let us know what it says on your next fill up.
I run E85 exclusively, and I never see more than E78 this time of year, and I usually see closer to E70 in the California winter. Highest I have seen was E82 in the summer.
05-22-2019, 06:17 PM | #5 |
Drives: 16' BRZ
With most setups don’t you not see much more gains above about 70% ethanol?
The Following User Says Thank You to GrabTheWheel For This Useful Post: | Sportsguy83 (05-22-2019) |
05-22-2019, 08:58 PM | #6 | |
your right, it has to be bad blend, usually my meter goes to e70-e80 when filling up completely on e85. i think im going to have to let Wawa know about this huge problem.
05-22-2019, 09:03 PM | #7 | |
Drives: Limited BRZ
Yup
05-23-2019, 07:31 AM | #8 |
Drives: brz 2017 hksv2
With NA setup probably E60 is already enough to reach MBT, that gives you room for bad batches of e85
05-23-2019, 11:22 AM | #9 |
Drives: 15 BRZ LTD, 05 FXT
But that doesn't mean you shouldn't tell the station that if it's marked as E85, it should be close to E85. If it lists a range, and it's within that range, it's ok. But E40 isn't E85.
Most likely decent blend, with E10 left in the tank is coming out to E40.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Tags |
e85, ethanol, flex fuel, subaru brz. |
Similar Threads | ||||
MAF scaling, showing you what i cam up with | trdric | Software Tuning | 24 | 06-29-2017 12:10 PM |
ECU Showing Throttle % ? | MatthewFRS | Issues | Warranty | Recalls / TSB | 4 | 12-06-2016 11:26 PM |
Defi meter installation problem | LEMON | DIY (Do-It-Yourself) Guides | 9 | 06-25-2016 05:00 PM |
showing off some new parts | Jhon19lopez | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 09-24-2013 10:53 AM |
